including model.sdf in .world Gazebo7
asked 2017-07-03 17:42:39 -0500
carolo gravatar image
Hi, im working since a couple weeks with gazebo and I have some problems including a model.sdf into a .world file.
I am using Gazebo7 and ROS-kinetic. I already sourced the MODEL_PATH at the .bashrc file
export GAZEBO_MODEL_PATH=/home/MyComputer/sim_ws/src/sim_sdf/models/vehicle/:$GAZEBO_MODEL_PATH
and the simulation is running when I start the model-file on its own. After testing I reduced the model-file:
<?xml version="1.0"?>
<sdf version="1.5">
    <model name="vehicle">
To include the model into the world file I use following command:
<sdf version="1.5">
  <world name="default">
      <uri>model://sun</uri>
<!-- Model -->
            <static>false</static>
        <uri>model://vehicle/model.sdf</uri>
        <pose> 0 0 1 0 0 0</pose>
  </world>
the problem is that gazebo is starting without a model and inside the terminal appears Directory doesn't exist[/home/MyComputer/sim_ws/src/sim_sdf/models/vehicle/model.sdf] So I tried to use
<uri>model://vehicle/model</uri>
that will take ages and still not work or
<uri>model://home/MyComputer/sim_ws/src/sim_sdf/models/vehicle/model</uri>
what also wont work.....
Hopefully there is somebody who had a similar problem and know what to do. I am totally stucked. Thank you in advance
answered 2017-07-03 18:04:33 -0500
sloretz gravatar image
It sounds like /home/MyComputer/sim_ws/src/sim_sdf/models/vehicle/ is a single model. That is, it has just one model.config in it. If so The GAZEBO_MODEL_PATH should be set to the directory that contains it. export GAZEBO_MODEL_PATH=/home/MyComputer/sim_ws/src/sim_sdf/models:$GAZEBO_MODEL_PATH. Then the URI should say just the model name <uri>model://vehicle</uri>.
Thanks for your quick answer. Now the model displays as some boxes and the terminal shows following massage: > libGL error: failed to create drawable
carolo gravatar imagecarolo ( 2017-07-05 06:50:02 -0500 )edit
I solved the problem, this happens when the path of the mesh file is not set correctly.
The following is the correct code:
<mesh>
<uri>/home/MyComputer/ros_ws/src/gazebo_sim/models/vehicle/meshes/DodgeBody.dae</uri>
<scale>2 2 2</scale>
</mesh>
Thanks for your help
carolo gravatar imagecarolo ( 2017-07-08 13:06:52 -0500 )edit
I'd expect `<uri>model://vehicle/meshes/DodgeBody.dae</uri>` to work if the `GAZEBO_MODEL_PATH` is set to the parent directory of `vehicle`. More info about environment variables used by gazebo is here http://gazebosim.org/tutorials?tut=components
sloretz gravatar imagesloretz ( 2017-07-10 10:10:03 -0500 )edit
Asked: 2017-07-03 17:24:20 -0500
Seen: 1,685 times
Last updated: Jul 05 '17
