How to: Use source installed version of Gazebo
asked 2017-07-06 08:10:46 -0500
SorinV gravatar image
updated 2017-07-06 08:11:06 -0500
I have ROS kinetic installed with gazebo_ros and all but I have to modify the simulator in order to skip this error.
How can I use the newly source copiled version of Gazebo 7?
answered 2017-07-06 17:35:15 -0500
iche033 gravatar image
you should be able to just install gazebo and export the LD_LIBRARY_PATH accordingly so that the source install version is used. If you build gazebo in a catkin workspace then sourcing the workspace setup file should take care of the paths.
Thanks for the answer. this would work if I am trying to use ros with it? I need to use gazebo_ros, which uses the default version and I don't know how to override it.
SorinV gravatar imageSorinV ( 2017-07-07 03:15:18 -0500 )edit
That worked, thanks. So my question is answered but I still have to find out how to spawn my robot in there because I cannot for now.
SorinV gravatar imageSorinV ( 2017-07-07 03:58:40 -0500 )edit
Asked: 2017-07-06 08:10:46 -0500
Seen: 89 times
Last updated: Jul 06 '17
