sdf model is not showing up correct
asked 2017-07-07 11:36:11 -0500
carolo gravatar image
Hi, I am not able to inserting my sdf model correctly into Gazebo7. If I start my model as a world file including the ground_plane and the sun it is showing up properly.
<?xml version="1.0"?>
<sdf version="1.5">
<!-- environment -->
  <world name="default">
<!-- light -->
      <uri>model://sun</uri>
<!-- Model -->
    <model name="vehicle">
  </world>
image description
As soon I am trying to start it as a model it will be displayed as boxes. Only changes is the following code:
<sdf version="1.5">
image description
The MODEL_PATH is set correctly, it also displays the correct name of the model-file which typed into the .config file. Maybe somebody can help me???
answered 2017-07-07 11:51:48 -0500
chapulina gravatar image
Are you trying to open the model file from the command line? Like gazebo model.sdf? That is not supported, only SDF files which have a <world> tag can be opened. Your first example is the correct way to do it.
You can also save the model file, open an empty world in Gazebo, and insert the model afterwards. See this tutorial.
It is possible for me to open the model from the command line as world "gazebo model.world" but it is not possible for me to open it as stand alone model.sdf when I am trying to insert it and gazebo7 is already running. I am starting up gazebo from the terminal using the command "gazebo". Maybe this is the mistake???
carolo gravatar imagecarolo ( 2017-07-08 05:47:35 -0500 )edit
I solved the problem. The Path of the meshes has not been set correctly.
The following is the correct code:
<mesh>
<uri>/home/MyComputer/ros_ws/src/gazebo_sim/models/vehicle/meshes/DodgeBody.dae</uri>
<scale>2 2 2</scale>
</mesh>
Thanks for your help
carolo gravatar imagecarolo ( 2017-07-08 12:53:14 -0500 )edit
Asked: 2017-07-07 11:36:11 -0500
Seen: 220 times
Last updated: Jul 07 '17
