Friction Not Working Between URDF and Database Model
asked 2017-08-03 11:25:28 -0600
rkeatin3 gravatar image
I am trying to model and control a conveyor using ROS/Gazebo, but right now it seems that objects I place on top of it just stay in place when I actuate it.
Here are screenshots showing the collision properties of the link from the URDF file and an example object: image description image description
I have attached the URDF file for the conveyor (ignore the .sdf extension added so that I could post it here). C:\fakepath\conveyor.urdf.xacro.sdf
Any ideas on how to debug this? Thanks!
answered 2017-08-08 10:04:35 -0600
Duckfrost gravatar image
updated 2017-08-08 10:19:31 -0600
I suppose you have the problem when moving the conveyor with the controllers. I made some tests to see what could be happening. My conclusion is that its highly probable that its something to do with the physiscs engine. Here you have a video that you can see the inconsistency in the way the objects interact with the standard ODE setting: Video Answer
conveyor belt working
Because depending on when and how the frictions work or they don't. Normally if you move the belt slow enough it will work because it will give the system time to make the friction calculations.
My recommendation is that you try different configurations in the ODE parameters in the world. Also try different friction parameters to make the friction bigger. But As I sais it seems more of a ODE system issue than the friction coeficients values.
You could for example try using the "world" solver type instead of the "quick". Its more precise. Also increase the itterations and the update rate.
I post here as much code as I can:
conveyor.urdf.xacro
main.launch
friction_test_object.urdf
conveyor.world
spawn_friction_test_object.launch
spawn_conveyor.launch
conveyor.yaml
conveyor_start_control.launch
Thanks for this incredibly thorough answer! It turns out that using the PositionJointInterface (as opposed to the EffortJointInterface) was the main problem I was facing; there was no friction at all using that interface. Maybe the lack of dynamics means that it wasn't exerting any force on the box? I did see problems with the conveyor significantly slipping underneath the database model I had been using, but using a custom model with high friction values solves that problem.
rkeatin3 gravatar imagerkeatin3 ( 2017-08-10 16:10:29 -0600 )edit
Asked: 2017-08-03 11:22:49 -0600
Seen: 1,185 times
Last updated: Aug 08 '17
