Write a Plugin. Should I know clearly about the function defined by gazebo if I want to write a plugin by myself?
asked 2017-08-17 06:12:24 -0500
Ji Cai gravatar image
I read about the tutorial of Write a Plugin. I don't understand the functions listed by the tutorial. Do you think I should learn about the header files first?
answered 2017-08-28 09:17:49 -0500
chapulina gravatar image
Gazebo's API is quite extensive, so it's probably not viable to "learn" all the functions. Depending on your use case, only a fraction of the functions will be relevant. For example, if you want to apply forces and velocities to parts of your robot, you'd need some functions from gazebo::physics::Link API. To tune a camera sensor, you'd look at gazebo::sensors::CameraSensor and so on.
Instead of going through the API, I suggest you search for keywords related to the problem you're trying to solve and go through some related tutorials and examples first. This way, you naturally start becoming familiar with the functions.
Thank you for your answer. It really helps me out!
Ji Cai gravatar imageJi Cai ( 2017-08-29 23:18:17 -0500 )edit
Glad to help :) Be sure to mark the answer as correct if that was enough for you, so other users can know in the future.
chapulina gravatar imagechapulina ( 2017-08-30 10:40:01 -0500 )edit
Asked: 2017-08-17 06:12:24 -0500
Seen: 606 times
Last updated: Aug 28 '17
