how to control the mobile robot (two wheels) moving?
asked 2017-08-21 11:13:32 -0500
langong gravatar image
In this tutorial http://gazebosim.org/tutorials?tut=bu... In step 10. Under the Force/Velocity tab, increase the force/velocity applied to each joint. The robot should move around. Question: How to set the different velocity for each wheel using C++ plugin. This means I can control the mobile robot to move using C++ code plugin, not set the velocity in the GUI of Gazebo by manually.
Thank you very much!
answered 2017-08-21 13:34:23 -0500
iche033 gravatar image
this tutorial on Setting Velocity on Joints and Links should help
It is working, Thank you very much!
langong gravatar imagelangong ( 2017-08-22 07:00:36 -0500 )edit
Asked: 2017-08-21 11:13:32 -0500
Seen: 553 times
Last updated: Aug 21 '17
