getting atlas.launch to run
asked 2013-03-09 15:25:43 -0500
cannot get atlas.launch to work. I installed 12.04 ubuntu 64 bit. installed ROS and gazebo as per the wiki page. When I ran the drc simulator atlas.launch.
I get the following. nny ideas..
Gazebo multi-robot simulator, version 1.4.0 Copyright (C) 2013 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
Msg Waiting for master.Msg Waiting for master Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 10.0.0.10 Xlib: extension "GLX" missing on display ":0". Error [RenderEngine.cc:623] Unable to create glx visual Warning [RenderEngine.cc:87] Unable to create X window. Rendering will be disabled
Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: 10.0.0.10 Xlib: extension "GLX" missing on display ":0". Error [RenderEngine.cc:623] Unable to create glx visual Warning [RenderEngine.cc:87] Unable to create X window. Rendering will be disabled Warning [InsertModelWidget.cc:242] The manifest.xml for a Gazebo model is deprecated. Please rename manifest.xml to model.config for model "/usr/share/drcsim-2.1/gazebomodels/environments/steppingblock" gazebo: /usr/include/boost/smartptr/sharedptr.hpp:418: T* boost::shared_ptr<t>::operator->() const [with T = gazebo::rendering::UserCamera]: Assertion `px != 0' failed.
answered 2013-03-11 08:49:24 -0500
Thanks! I have a lenovo thinkpad w520 which comes with nvidia quadro card but I did not install any additional drivers. It is currently using the default ubuntu drivers. I did not see nvidia drivers for quadro board on the list of nvidia drivers anyway.
check if your GPU is properly installed, here is a way: install mesa utils $ sudo apt-get install mesa-utils and then run $ glxgears
AndreiHaidu gravatar imageAndreiHaidu ( 2013-03-11 10:46:21 -0500 )edit
answered 2013-03-10 07:04:33 -0500
Most probably you have a graphic card with optimus drive which does not work properly under linux. You could try the bubmlebee project see if it works with that, if not I think you have to uninstall the nvidia drivers and just use the default ones from ubuntu. This meaning that the computer is going to use the onboard GPU not the dedicated one, which will be a lot slower.
Cheers, Andrei
Thanks, I was having a similar problem and your suggestion of trying the bumblebee project fixed it.
Airuno2L gravatar imageAiruno2L ( 2013-11-07 07:55:21 -0500 )edit
Asked: 2013-03-09 15:25:43 -0500
Seen: 675 times
Last updated: Mar 11 '13
