Could not find a package configuration file provided by "gazebo" with any of the following names:gazeboConfig.cmake gazebo-config.cmake
asked 2017-09-07 12:43:17 -0500
Ji Cai gravatar image
What should I do to solve this problem?image description
Same issue......I have even installed Libgazebo5-dev ...but same error....Can anybody help on this please?
GORO_CHAT gravatar imageGORO_CHAT ( 2018-07-22 12:10:26 -0500 )edit
answered 2017-09-07 12:58:53 -0500
sloretz gravatar image
Which version of gazebo is installed? Find out using gazebo --version. For example, I have gazebo 7.
$ gazebo --version
Gazebo multi-robot simulator, version 7.7.0
http://gazebosim.org
You'll need the the dev package for that version of gazebo. For gazebo 7 run sudo apt install libgazebo7-dev.
You can find more information about setting up a computer to build plugins in the first few sections of this tutorial http://gazebosim.org/tutorials?tut=gu....
I have solved this problem by following the installation tutorial, and 'sudo' the basic files. Thank you for your help.
Ji Cai gravatar imageJi Cai ( 2017-09-07 13:05:31 -0500 )edit
I have installed Libgaebo5-dev but still the error is same. What could be the reason?
GORO_CHAT gravatar imageGORO_CHAT ( 2018-07-22 01:51:27 -0500 )edit
Even after installing libgazebo4-dev, the error remained the same on indigo ros+Gazebo 5
GORO_CHAT gravatar imageGORO_CHAT ( 2018-07-22 12:08:47 -0500 )edit
2 followers
Asked: 2017-09-07 12:43:17 -0500
Seen: 3,414 times
Last updated: Sep 07 '17
