Segmentation Fault on Load Function
asked 2017-09-23 08:22:04 -0500
Haini gravatar image
I am trying to run the Hello World Plugin Tutorial from the Gazebo Website.
After following all the steps and executing gzserver ~/gazebo_plugin_tutorial/hello.world --verbose the "Hello World" Message from the Constructor ist posted, but after that noting happens.
Debugging the Plugin / Gzserver with gdb and Debugging Symbols activated yields the following output: https://pastebin.com/QV0PdFQJ
With the backtrace:
#0  __memcpy_sse2_unaligned () at ../sysdeps/x86_64/multiarch/memcpy-sse2-unaligned.S:160
#1  0x00007ffff71c53c2 in std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_assign(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
   from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#2  0x00007ffff62a5ed2 in ?? () from /usr/lib/x86_64-linux-gnu/libgazebo_physics.so.7
#3  0x00007ffff628b3cd in gazebo::physics::World::LoadPlugin(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::shared_ptr<sdf::Element>) ()
#4  0x00007ffff628d879 in gazebo::physics::World::LoadPlugin(std::shared_ptr<sdf::Element>) ()
#5  0x00007ffff628dbb0 in gazebo::physics::World::LoadPlugins() ()
#6  0x00007ffff62a0345 in gazebo::physics::World::Step() ()
#7  0x00007ffff62a06d5 in gazebo::physics::World::RunLoop() ()
#8  0x00007ffff40435d5 in ?? () from /usr/lib/x86_64-linux-gnu/libboost_thread.so.1.58.0
#9  0x00007ffff65c36ba in start_thread (arg=0x7fffb9bc6700) at pthread_create.c:333
#10 0x00007ffff6bcd3dd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:109
My code is exactly as specified in the tutorial, with the exception of the Makefile where the Debug Symbols are added.
gazebo -v yields version 7.8.1
cmake --version yields version 3.5.1
make -v yields GNU Make 4.1
lsb-release -a yields Ubuntu 16.04.3 LTS
roscore -v yields /rosdistro: kinetic and /rosversion: 1.12.7
What am I doing wrong? My only guess is that I am running Gazebo within VirtualBox and only have a Intel Core i7-4500U with Integrated Graphics (whereas Gazebo states it needs a dedicated NVIDA Card). But running Gazebo without plugins works just fine, so there needs to be a hint that I am missing.
answered 2017-09-25 04:07:33 -0500
The problem seems to be related with me using g++ and gcc < 5.0 as the default, while completely removing g++ and gcc > 5.0 (5.4 in my case) from the priority list with the update-alternatives utility.
After setting up a fresh VirtualBox Machine everything worked out fine and I was able to reproduce the behavior on my real Ubuntu 16.04 install - where the same default compiler settings were made.
As a bonus I was then able to compile the V-REP RosInterface and use it without producing segmentation faults. So the issue is most probable related to the ROS Part of the process.
I guess Simulink / Matlab will have to live with the fact that the default compiler is not supported, at least they can fallback to the older versions after producing some error messages.
Asked: 2017-09-23 08:22:04 -0500
Seen: 771 times
Last updated: Sep 25 '17
