texture doesn't load properly
asked 2017-10-04 21:37:29 -0600
yjy765 gravatar image
updated 2017-10-04 21:38:53 -0600
I downloaded rotors_simulator and execute yosemite.world in gazebo
Following is the screenshot for it
image description
(I removed the grass plane model so it contains only yosemite.sdf in the world file)
And the following is yosemite model sdf code
<?xml version="1.0" ?>
<sdf version="1.4">
  <model name="yosemite">
          <heightmap>
            <uri>model://yosemite/materials/textures/yosemite.png</uri>
            <size>1000 1000 125</size>
           <pos>0 0 -15</pos>
          </heightmap>
        <surface>
          <friction>
            <ode>
              <mu>0.2</mu>
              <mu2>0.2</mu2>
            </ode>
          </friction>
        </surface>
          <heightmap>
            <texture>
              <diffuse>file://media/materials/textures/dirt_diffusespecular.png</diffuse>
              <normal>file://media/materials/textures/flat_normal.png</normal>
              <size>50</size>
            </texture>
            <texture>
              <diffuse>file://media/materials/textures/terrain_detail.jpg</diffuse>
              <size>75</size>
            </texture>
            <texture>
              <diffuse>file://yosemite/materials/textures/texture_forest.png</diffuse>
              <size>100</size>
            </texture>
            <texture>
              <diffuse>file://yosemite/materials/textures/texture_mountains.png</diffuse>
              <size>50</size>
            </texture>
            <blend>
              <min_height>35</min_height>
              <fade_dist>10</fade_dist>
            </blend>
            <blend>
              <min_height>60</min_height>
            </blend>
            <blend>
              <min_height>90</min_height>
            </blend>
            <pos>100 0 -30</pos>
          </heightmap>
And the texture file can be found at https://github.com/ethz-asl/rotors_si... (I can't upload it due to the maximum size limit, sorry)
So I think the former two texture file is loaded well, which are given in gazebo. On the other hand, the latter two texture file is not loaded properly, which are given by user.
How can I address this issue?
3
answered 2017-10-05 06:49:49 -0600
wentz gravatar image
May be a problem with the path's that gazebo is using. For example when you use model:// to include a file
it will look in $GAZEBO_MODEL_PATH/yosemite/materials/textures/yosemite.png to load the image. Everything you include with file://
gazebo will search in $GAZEBO_RESOURCE_PATH/media/materials/textures/dirt_diffusespecular.png
Did you made sure that these path's and directories are set correct and that the png files are in the right locations? You can check the path's with
echo $GAZEBO_MODEL_PATH
echo $GAZEBO_RESOURCE_PATH
Thanks!! @wentz you're right I set $GAZEBO_MODEL_PATH but I didn't know about GAZEBO_RESOURCE_PATH
yjy765 gravatar imageyjy765 ( 2017-10-05 23:37:40 -0600 )edit
Asked: 2017-10-04 21:37:29 -0600
Seen: 1,038 times
Last updated: Oct 05 '17
