Dae texture loading error
asked 2017-10-23 00:01:02 -0500
yjy765 gravatar image
updated 2017-10-23 06:16:45 -0500
Hello, I am trying to create a model from Blender and then import the dae file in Gazebo
First, I tried to make a tree with the files in gazebo_osrf/pine-tree ( https://bitbucket.org/osrf/gazebo_mod...) I am going to make another model so please don't tell me just use the given model
And the result is as follow: image description
The leaf texture was loaded well but bark seems not being loaded
Following link contains all files I made: https://www.dropbox.com/sh/e8zc9srm8v...
There is no clear tutorial for how to create sdf files, material files etc so I just mimic what 'pine tree' models just did.
What did I do wrong and what should I do?
I would really appreciate if anyone tell me in detail. Thanks
Added::
I think adding mesh on plane goes well. But adding mesh on cube or cylinder etc just takes a simple color of mesh image.(Brown color for bark image)
p.s. In Blender, all parts look well
when you export the dae file from blender, did you also export the texture uv coordinates? I remember there is an checkbox option for this
iche033 gravatar imageiche033 ( 2017-10-23 20:22:55 -0500 )edit
answered 2017-10-24 10:54:42 -0500
chapulina gravatar image
You're almost there. By applying the bbb/Circle material to the Plane submesh (the trunk), you're telling Ogre to override the material defined on the Collada file. However, the mesh still needs to have proper UV coordinates so Ogre knows how to distribute the texture along the mesh. That's currently not well set, so the mesh is stretched in such a weird way that the tree looks like it has a plain brown color.
I did a quick dirty UV projection using Blender's "Smart UV Project" and the updated DAE works with your material files:
image description
You can see the texture is stretched though, so you would probably be better off carefully adjusting the texture instead of using smart UV project. Search online for tutorials on UV unwrapping with Blender ;)
Thank you so much! It works!
yjy765 gravatar imageyjy765 ( 2017-10-25 05:00:49 -0500 )edit
Glad to hear :) Feel free to accept the answer so others know it works in the future
chapulina gravatar imagechapulina ( 2017-10-25 10:12:58 -0500 )edit
Asked: 2017-10-23 00:01:02 -0500
Seen: 1,478 times
Last updated: Oct 24 '17
