2
gazebo default directory and can not insert model
asked 2012-11-08 09:28:33 -0600
  1. where is the gazebo difault directory,I use virtualbox run ros and gazebo, I can only insert the default model from its default directory, and must use "sudo" command to modify the model file.so when I follow tutorial 'build a robot' , I can't insert the model from my created directory, why? Please help me.
  2. In the tutorial 'build a robot', after creating ~/.gazebo/models/manifest.xml file and ~/.gazebo/models/my_robot/model.sdf file, but I can not insert it , because I can not find the file and gazebo only can insert .model file, why? how to solute it?
  3. gazebo_models,but I find the example model in the opt/ros/fuerte/stacks/simulator_gazebo/gazebo/gazebo/share/model, how can I change the default directory to my created directory ~/.gazebo/models/
thanks
2
answered 2012-11-09 09:53:08 -0600
Answered it earlier, i suggest just posting one question?
You can set the default directories for models using (go sudo gedit ~/.bashrc and add this for example)
export GAZEBO_MODEL_PATH=path/to/models
For world files gazebo looks in your current directory (i think) and the resource path.
export GAZEBO_RESOURCE_PATH=path/to/worlds.
But you can always all this path stuff by creating a world file completely without inserts, yourworld.sdf
<?xml version="1.0" ?>
<gazebo version="1.2">
  <world name="default">
     <model name="yourmodel">
        <link name='yourlink'>
         <self_collide>false</self_collide>
          <pose>0.0000 0.0000 0.0000 0.000 0.000 0.000</pose>
          <collision name='yourlink'>
            <box><size>0.6 0.5 0.34</size></box>
          <visual name='yourlink'>
  </world>
Save it as yourmodel.sdf. Then go in prompt and type gazebo yourmodel.sdf (in that directory)
it looks like lugd1229 is using ros, in which case the export commands wouldn't work right?
mcevoy.andy gravatar imagemcevoy.andy ( 2012-11-09 10:25:08 -0600 )edit
yes ,I use simulator_gazebo ,then I try to use plain gazebo, maybe it is more simple. thank you.
lugd1229 gravatar imagelugd1229 ( 2012-11-09 11:30:53 -0600 )edit
Ah yes, i missed the ROS in the first sentence. I guess it won't work.
Erik Stoltenborg gravatar imageErik Stoltenborg ( 2012-11-09 13:56:30 -0600 )edit
answered 2016-12-28 03:24:09 -0600
prasad gravatar image
Typically, there are 3 methods to let Gazebo software load a model as mentioned in this answer.
  1. Export GAZEBO_MODEL_PATH properly. (If Gazebo doesn't start at all, then setup Gazebo and environment variables and then export GAZEBO_MODEL_PATH)
  2. Move the models to "gazebo/models" folder directly and include the URI in launch file.
  3. In case this is being used with ROS (which is the typical case), make sure that the models and the code is withinthe workspace. (I was struggling with this and I was attempting multi-robot simulation. I realised that the environment variables are sourced in the first instance and sourcing them again from second workspace or any other folder can be difficult. Reference : http://wiki.ros.org/catkin/Tutorials/... )
[Note: I am posting this to help people; I myself struggled to get a working solution (for about 10 hours) and I haven't found any similar information as in this answer]
@prasaid what you mean by "can be difficult" ? You cannot source more than one workspace?
bxl gravatar imagebxl ( 2017-11-22 14:27:50 -0600 )edit
answered 2016-10-24 08:53:45 -0600
bergercookie gravatar image
export the following shell variables (e.g. in your ~/.bashrc):
  1. export GAZEBO_MODEL_PATH=path/to/models
  2. export GAZEBO_RESOURCE_PATH=path/to/worlds.
Also make sure that all the .sdf files in the model path are inside their corresponding folders and have a model.config file beside them. If the latter is not there the model is not going to be found by gazebo. e.g.
MODELS_DIRECTORY/
|-->pioneer_3at/
    |--> model.sdf
    |--> model.config
Asked: 2012-11-08 09:28:33 -0600
Seen: 24,027 times
Last updated: Nov 14 '12
