Mesh problem on ros kinetic but not indigo
asked 2017-11-12 21:25:17 -0600
ylchong gravatar image
I have a urdf which uses meshes for visualisation. I can open the urdf fine from ros indigo with Gazebo 7 (I unistalled Gazebo 2).
However, I cannot open the urdf from my ros launch file. I get the following error:
terminate called after throwing an instance of 'Ogre::InvalidParametersException' what(): OGRE EXCEPTION(2:InvalidParametersException): Header chunk didn't match either endian: Corrupted stream? in Serializer::determineEndianness at /build/ogre-1.9-jztnFF/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreSerializer.cpp (line 89)
I found that if I remove the mesh reference and it runs without problems (but with no visuals, of course).
The mesh is called from the urdf: <visual> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <mesh filename="package://prius_description/meshes/hybrid_body.obj" scale="0.01 0.01 0.01"/> </geometry> </visual> inside of the link tag.
The code ran fine on 2 PCs with ROS Indigo + Gazebo7 but could not run on any ROS Kinetic comps.
Any ideas as to why/ how to fix this?
