2
Gravity Disabled on Robot Pinned to World
asked 2012-11-08 10:25:27 -0500
liangfok gravatar image
updated 2012-11-29 15:15:10 -0500
I have a simple robot with four links and four revolute joints. The first joint is pinned to the world. When I run the simulation, the robot is not affected by gravity. I know gravity is enabled because when I drag another object like a box and drop it into the world, it falls down. I suspect that gravity is not affecting my four-link robot because it is pinned to the world. Could this be the case? How can I enable gravity for my robot?
Update: The problem was fixed by specifying collision elements for each link in the robot. This is strange since collisions and dynamics should be decoupled. Should this be considered a bug?
can you post your robot model? (with and without collision bodies?)
hsu gravatar imagehsu ( 2012-11-12 12:24:06 -0500 )edit
can you change your question's title to reflect the issue? i.e. dynamics disabled if missing collision element? thanks.
hsu gravatar imagehsu ( 2012-11-30 20:43:28 -0500 )edit
answered 2012-11-30 20:42:28 -0500
hsu gravatar image
It appears if a model does not have any collision elements, it behaves statically, ticketed here.
scpeters gravatar imagescpeters ( 2013-01-11 18:14:25 -0500 )edit
[This issue has been resolved](https://bitbucket.org/osrf/gazebo/issue/274).
scpeters gravatar imagescpeters ( 2013-01-11 18:14:32 -0500 )edit
answered 2012-11-09 13:44:57 -0500
nkoenig gravatar image
Creating a joint between a model and the world (aka pinning the model to the world), will enforce a joint constraint between the robot and world. This is usually only used if you want to the robot to remain in on fixed location.
I think you may have pinned the robot, and it looks like gravity is not working because the joint is just holding the robot in place.
Asked: 2012-11-08 10:25:27 -0500
Seen: 532 times
Last updated: Nov 30 '12
