Magnetic Guide Sensor - follow magnetic line
asked 2017-11-15 07:29:28 -0500
lukup gravatar image
Does anyone have experience with magnetic guide sensors in combination with ROS or GAZEBO ?
I want to add a magnetic guide sensor to my model to follow a magnetic line on the world. I haven't found anything about this topic yet and looking forward to any advice.
Thank you in advance.
Howdy. Are you asking how to simulate a magnetic sensor? (see the magnetic plugin here http://wiki.ros.org/hector_gazebo_plugins), or how to follow a magnetic line? With the latter, do you mean holding a particular magnetic heading, or aligning the sensor with the local magnetic field?
Galto2000 gravatar imageGalto2000 ( 2017-11-18 08:15:54 -0500 )edit
Hi @Galto2000 I was asking for following a magnetic track with a sensor capable of detecting and reporting the position of the magnetic field along its horizontal axis.
lukup gravatar imagelukup ( 2017-11-19 08:25:10 -0500 )edit
Do you mean you want to travel along a magnetic field line (e.g. from south to north)?
Galto2000 gravatar imageGalto2000 ( 2017-11-19 19:31:20 -0500 )edit
No, the vehicle should travel along a magnetic tape attached to the floor. I think it's only minor influenced by the terrestrial magnetic field. Similar to follow line via camera sensor only with a magnetic sensor
lukup gravatar imagelukup ( 2017-11-20 04:39:30 -0500 )edit
Gotcha. Presuming the question is how to simulate a Hall-effect sensor interacting with the magnetic tape path: I would base this on a 2D point to line segment distance computation. The magnetic tape path consists of multiple connected segments. The sensor consists of points on a line probably perpendicular to the longitudinal axis: for every point, compute the distance to each line segment. If within sensor range, use the sign to determine "left" or "right". I'd use a world-plugin for this.
Galto2000 gravatar imageGalto2000 ( 2017-11-20 17:07:16 -0500 )edit
