Logical camera refence frame affecting GUI reference frame
asked 2017-11-21 04:14:59 -0500
ylchong gravatar image
I am using a sensor logical_camera as part of a radar plugin (github: https://github.com/ros-simulation/gaz...) which works perfectly fine; except when visualised ie. <visualize>true</visualize>
When set to true, in the GUI, all other objects spawn at the reference frame of the joint of the logical camera. If the unit box or sphere or cylinder is added using the GUI, the objects get spawned with the transformation of the joint frame (not at where the objects were placed using the mouse).
For example, if I set
<joint name="${name}_camera_joint" type="fixed">
<origin xyz="10 0 0" rpy="0 0 0"/>
<parent link="${parent}"/>
<child link="${name}_link"/> </joint>
And then try to add a unit sphere using the GUI, upon clicking on a location, the sphere disappears and re-appears at a location 10m to the right (along the x-axis).
<gazebo reference="radar_mount">
    <sensor name="logical_camera" type="logical_camera">
      <logical_camera>
        <near>0.2</near>
        <far>2.0</far>
        <horizontal_fov>1.04719755</horizontal_fov>
        <aspect_ratio>1.778</aspect_ratio>
      </logical_camera>
      <visualize>false</visualize>
      <always_on>true</always_on>
      <update_rate>10</update_rate>
And if the visualize is set to false, none of the above issues occur.
I am on ROS Indigo + Gazebo7. Any idea why this is happening?
answered 2017-11-21 11:06:57 -0500
Sounds like this open issue:
https://bitbucket.org/osrf/gazebo/iss...
Yeah, looks like it is... Thanks! I ll mark as answered for now
ylchong gravatar imageylchong ( 2017-11-22 07:19:25 -0500 )edit
Asked: 2017-11-21 04:14:59 -0500
Seen: 65 times
Last updated: Nov 21 '17
