Gazebo - How to manually input coordinates of objects
asked 2017-11-30 08:44:32 -0600
Multiplexer gravatar image
Im using gazebo 2.2 (ubuntu 14 trustly with ROS indigo). I created my world with a TurtleBot robot inside for simulation purposes.
Now what I'm looking for is a way to manually input initial coordinates of objects. I want to select an object, for example said Turtlebot (mobile_base) and then place it exactly at X = 1.5, Y = 1.5, Z = 0 and then give it rotation yaw = -1
How do i do it?
When i select world object mobile_base it has "pose" property that can be edited but i cant see a way to save these new values, each time i click outisde of the world tab, they reset to previous values.
answered 2017-11-30 10:11:27 -0600
chapulina gravatar image
updated 2017-12-01 10:47:43 -0600
It sounds like you're just starting, so I'd recommend you step back a bit and reinstall everything to run ROS Kinetic with Gazebo 7, since Gazebo 2 hasn't been supported for a long time.
After that, I recommend you go through Gazebo + ROS tutorials before diving into the code: http://gazebosim.org/tutorials?cat=co...
Update
Is this what you're trying to do? This is Gazebo 7.8.1:
image description
Note that Gazebo 2 being outdated is only one of the possible reasons why it isn't working for you. You could have a joint pulling the robot back to the original place, or some ROS node publishing poses...
So entering object coordinates by hand *while designing world* is not supported in gazebo 2.2? Is it a confirmed feature in Gazebo 7? I dont want to change my whole configuration just to find out that its not possible either in Gazebo 7. Thank you for reply.
Multiplexer gravatar imageMultiplexer ( 2017-12-01 01:17:47 -0600 )edit
I updated the answer to address this comment. I'm not saying it isn't possible on Gazebo 2, just that I wouldn't be surprised if it weren't working there.
chapulina gravatar imagechapulina ( 2017-12-01 10:48:43 -0600 )edit
thanks you thats what i was looking for, im installing Gazebo 7 with kinetic to see if it works
Multiplexer gravatar imageMultiplexer ( 2017-12-04 01:27:11 -0600 )edit
Asked: 2017-11-30 08:44:00 -0600
Seen: 1,056 times
Last updated: Dec 01 '17
