GZServer problem >> Could not open file[empty.world]
asked 2013-03-14 06:56:50 -0600
updated 2013-03-19 17:39:50 -0600
I have ubuntu 12.04 and installed gazebo by Pre-compiled binaries from here
i don't any change in bashrc expect:
source /usr/share/gazebo/setup.sh
mohsen@mohsen-ThinkPad-R500:~$ gdb --args gzserver empty.world
GNU gdb (Ubuntu/Linaro 7.4-2012.02-0ubuntu2) 7.4-2012.02
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
For bug reporting instructions, please see:
<http://bugs.launchpad.net/gdb-linaro/>...
Reading symbols from /usr/bin/gzserver...Reading symbols from /usr/lib/debug/usr/bin/gzserver-
1.5.0...done.
done.
(gdb) run
Starting program: /usr/bin/gzserver empty.world
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffe5293700 (LWP 4328)]
Gazebo multi-robot simulator, version 1.5.0
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Error [Server.cc:238] Could not open file[empty.world]
[Thread 0x7fffe5293700 (LWP 4328) exited]
[Inferior 1 (process 4252) exited with code 0377]
(gdb)
mohsen@mohsen-ThinkPad-R500:~$ echo $GAZEBORESOURCEPATH
/usr/share/gazebo-1.5:/usr/share/gazebo_models
and there is my empty.world: /usr/share/gazebo-1.5/worlds/empty.world
answered 2013-03-14 07:37:16 -0600
AndreiHaidu gravatar image
you have to add the path to the .world file
$ gzserver /<path>/share/gazebo-1.5/worlds/empty.world
Cheers, Andrei
gzserver /usr/share/gazebo-1.5/worlds/empty.world . after run gzclientin another terminal this error showed: "Segmentation fault (core dumped)" and this window opened: "The application Gazebo has closed unexpectly" and it gave me this title for error "gzserver-1.5.0 crashed with SIGABRT in raise()". help plz
Mohsen Hk gravatar imageMohsen Hk ( 2013-03-14 08:38:20 -0600 )edit
I recreated the steps with gazebo 1.5 and for me it works. Do you get the same error when you run $ gazebo /<path>/share/gazebo-1.5/worlds/empty.world ? Or just simply $ gazebo ? Maybe you are loading something from your world file that gives a segfault.
AndreiHaidu gravatar imageAndreiHaidu ( 2013-03-14 11:31:02 -0600 )edit
i'm trying to install gazebo again but it gave me this error: http://answers.gazebosim.org/question/1837/sudo-apt-get-install-gazebo-gazebo-depends-but-it/
Mohsen Hk gravatar imageMohsen Hk ( 2013-03-15 04:35:06 -0600 )edit
Asked: 2013-03-14 06:56:50 -0600
Seen: 3,710 times
Last updated: Mar 19 '13
