Publishing to jointTrajectoryController
asked 2017-12-19 11:11:25 -0600
Fiddle gravatar image
Hi, I've been wanting to set up my floating gripper with a controller package, like in the example here but I can't seem to find a way to publish a message, for example, for a joint gripper_dummy_prismatic_joint to move by 0.1 distance in gazebo. Below are the .yaml file for gripper control and the rostopic list output. In gazebo tutorial about connecting ros with gazebo it seems very simple, but I can't figure out how to do this with the interface written as on the ros page. I want preferably to send messages by python. I'd post this on the ROS answers, but the site seems to be down for a week now :(
.yaml
gripper:
  # Publish all joint states -----------------------------------
  joint_state_controller:
    type: "joint_state_controller/JointStateController"
    publish_rate: 50
  # Trajectory Controllers ---------------------------------------
  joint_trajectory_controller:
    type: "effort_controllers/JointTrajectoryController"
    joints:
     - gripper_dummy_prismatic_joint
     - gripper_dummy_revolute_joint
     - gripper_joint1
     - gripper_joint2
    gains:
       gripper_dummy_prismatic_joint: {p:  6000,  d: 1000 , i: &ki_default 1.0, i_clamp: &ki__clamp_default 2}
       gripper_dummy_revolute_joint: {p: &kp_default 8000 ,  d: &kd_default 25.0 , i: *ki_default, i_clamp: *ki__clamp_default}
       gripper_joint1: {p: *kp_default ,  d: *kd_default , i: *ki_default, i_clamp: *ki__clamp_default}
       gripper_joint2: {p: *kp_default ,  d: *kd_default , i: *ki_default, i_clamp: *ki__clamp_default}
    constraints:
       goal_time: &goal_time_constraint 40.0
       stopped_velocity_tolerance: 5.0
          goal: &goal_pos_constraint 0.5
          trajectory: &trajectory_pos_constraint 0.5
          goal: *goal_pos_constraint
          trajectory: *trajectory_pos_constraint
       gripper_joint1:
       gripper_joint2:
       stop_trajectory_duration: 1.0
rostopic list:
/clock
/gazebo/link_states
/gazebo/model_states
/gazebo/parameter_descriptions
/gazebo/parameter_updates
/gazebo/set_link_state
/gazebo/set_model_state
/gripper/joint_states
/gripper/joint_trajectory_controller/command
/gripper/joint_trajectory_controller/follow_joint_trajectory/cancel
/gripper/joint_trajectory_controller/follow_joint_trajectory/feedback
/gripper/joint_trajectory_controller/follow_joint_trajectory/goal
/gripper/joint_trajectory_controller/follow_joint_trajectory/result
/gripper/joint_trajectory_controller/follow_joint_trajectory/status
/gripper/joint_trajectory_controller/gains/gripper_dummy_prismatic_joint/parameter_descriptions
/gripper/joint_trajectory_controller/gains/gripper_dummy_prismatic_joint/parameter_updates
/gripper/joint_trajectory_controller/gains/gripper_dummy_revolute_joint/parameter_descriptions
/gripper/joint_trajectory_controller/gains/gripper_dummy_revolute_joint/parameter_updates
/gripper/joint_trajectory_controller/gains/gripper_joint1/parameter_descriptions
/gripper/joint_trajectory_controller/gains/gripper_joint1/parameter_updates
/gripper/joint_trajectory_controller/gains/gripper_joint2/parameter_descriptions
/gripper/joint_trajectory_controller/gains/gripper_joint2/parameter_updates
/gripper/joint_trajectory_controller/state
/rosout
/rosout_agg
/tf
/tf_static
answered 2017-12-20 05:20:42 -0600
I've found the answer, it was rather trivial,
allow_partial_joints_goal: true
needs to be added to the yaml file, then I can publish the messages through
rostopic pub /gripper/joint_trajectory_controller/command trajectory_msgs/JointTrajectory
then I can specify which joint I want to move.
Asked: 2017-12-19 11:11:25 -0600
Seen: 1,493 times
Last updated: Dec 20 '17
