uri file attribute in SDF files
asked 2012-11-09 06:07:32 -0600
logicalguy gravatar image
If the file path is relative, which is the base directory and how can we specify it?
Thanks
I think its the directory of the world file, are you also getting directory not found error?
Erik Stoltenborg gravatar imageErik Stoltenborg ( 2012-11-09 09:51:56 -0600 )edit
Hi, I am getting an error that says "Image filename is empty"
logicalguy gravatar imagelogicalguy ( 2012-11-12 05:40:42 -0600 )edit
I believe this is an error that you can ignore, and has been removed in the default branch. Are you experiencing any related problems?
nkoenig gravatar imagenkoenig ( 2012-11-14 10:21:52 -0600 )edit
when I specify a png heightmap, it doesn't load the heightmap, instead a large 2d black rectangle where the heightmap should be. The Pioneer robot is next to this space on the ground. I have attached a screenshot of gazebo, my heightmap mage, and the world file at http://inky.ws/g/2cz
logicalguy gravatar imagelogicalguy ( 2012-11-16 05:36:54 -0600 )edit
oh, and I am using gazebo-1.2.5
logicalguy gravatar imagelogicalguy ( 2012-11-16 05:41:50 -0600 )edit
answered 2013-01-11 19:13:34 -0600
updated 2013-07-23 16:53:10 -0600
Base paths for relative URIs are specified in environment variables. For example GAZEBO_RESOURCE_PATH.
Asked: 2012-11-09 06:07:32 -0600
Seen: 1,477 times
Last updated: Jul 23 '13
