sudo apt-get install gazebo > gazebo : Depends: ... but it is not installable
asked 2013-03-15 03:40:31 -0600
updated 2013-03-15 04:33:55 -0600
Hi, How can i fix this problem? tnx
mohsen@mohsen-ThinkPad-R500:~$ sudo apt-get install gazebo
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
gazebo : Depends: libboost-thread1.49.0 but it is not installable
      Depends: libboost-signals1.49.0 but it is not installable
      Depends: libboost-system1.49.0 but it is not installable
      Depends: libboost-filesystem1.49.0 but it is not installable
      Depends: libboost-program-options1.49.0 but it is not installable
      Depends: libboost-regex1.49.0 but it is not installable
      Depends: libboost-iostreams1.49.0 but it is not installable
      Depends: libcegui-mk2-0.7.6 but it is not installable
E: Unable to correct problems, you have held broken packages.
answered 2013-03-15 06:40:16 -0600
Jose Luis Rivero gravatar image
Boost1.49.0 is listed as a dependency for gazebo in the quantal version. Be sure you are not running a precise distribution using a quantal sources.list in /etc/apt/sources.list.d/.
If that is not the reason, some extra information is would be good:
  1. Ubuntu distribution being used and architecture (32/64bits)
  2. Clean installation or upgrading?
  3. Output from > grep osrfoundation > /etc/apt/sources.list.d/*.list
tnx! (in gazebo-latest.list >> deb http://packages.osrfoundation.org/gazebo/ubuntu quantal main) (in ros-latest.list >>deb http://packages.ros.org/ros/ubuntu precise main) i change it to0 "precise" and trying to re install with synaptic. it's work
Mohsen Hk gravatar imageMohsen Hk ( 2013-03-18 18:55:05 -0600 )edit
Asked: 2013-03-15 03:40:31 -0600
Seen: 755 times
Last updated: Mar 15 '13
