How can I add a camera publishing to a ros topic from an sdf file
asked 2018-02-13 23:31:56 -0500
ashwinvk94 gravatar image
I am working on simulating a quadcopter using the px4 sitl simulator and I want to add a camera which publishes images to a ros topic. The simulator contains a quadcopter model derived from the rotorS model.
But unlike the original rotorS model, the quadcopter model is described using an sdf file rather than a urdf file. Although I understood how to add a ROS topic publishing camera using the URDF file, I did not understand how to do the same using sdf files.
I am pasting the sdf file here, please tell me how I can add a camera which publishes to a ros topic by editing this sdf file. C:\fakepath\iris.sdf
How is going? any success?
AchmadFathoni gravatar imageAchmadFathoni ( 2018-05-24 10:24:08 -0500 )edit
Could you add to your question the way you'd add it to a URDF? It should be quite similar, with some minor tweaks
chapulina gravatar imagechapulina ( 2018-05-24 12:43:55 -0500 )edit
