having problem with rosluanch a gazebo file
asked 2018-03-12 04:28:02 -0500
aminGolden gravatar image
hello
I made a project for gazebo and I ran it in my computer ,but when I run it on my friend computer whit same files I have these error :
roslaunch ros_robotics ddrobot_gazebo.launch
... logging to /home/toki/.ros/log/fb16499c-25d5-11e8-b86e-8056f2be489d/roslaunch-toki-6169.log
Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://toki:33131/
SUMMARY
PARAMETERS * /rosdistro: kinetic * /rosversion: 1.12.12 * /use_sim_time: True
NODES / gazebo (gazebo_ros/gzserver) gazebo_gui (gazebo_ros/gzclient) spawn_urdf (gazebo_ros/spawn_model)
auto-starting new master process[master]: started with pid [6179] ROS_MASTER_URI=http://localhost:11311
setting /run_id to fb16499c-25d5-11e8-b86e-8056f2be489d process[rosout-1]: started with pid [6192] started core service [/rosout] process[gazebo-2]: started with pid [6196] process[gazebo_gui-3]: started with pid [6209] process[spawn_urdf-4]: started with pid [6224] Traceback (most recent call last): File "/opt/ros/kinetic/lib/gazebo_ros/spawn_model", line 32, in <module> import tf.transformations as tft File "/opt/ros/kinetic/lib/python2.7/dist-packages/tf/__init__.py", line 28, in <module> from tf2_ros import TransformException as Exception, ConnectivityException, LookupException, ExtrapolationException File "/opt/ros/kinetic/lib/python2.7/dist-packages/tf2_ros/__init__.py", line 39, in <module> from .buffer_interface import * File "/opt/ros/kinetic/lib/python2.7/dist-packages/tf2_ros/buffer_interface.py", line 32, in <module> import roslib; roslib.load_manifest('tf2_ros') File "/opt/ros/kinetic/lib/python2.7/dist-packages/roslib/launcher.py", line 62, in load_manifest sys.path = _generate_python_path(package_name, _rospack) + sys.path File "/opt/ros/kinetic/lib/python2.7/dist-packages/roslib/launcher.py", line 93, in _generate_python_path m = rospack.get_manifest(pkg) File "/usr/lib/python2.7/dist-packages/rospkg/rospack.py", line 167, in get_manifest return self._load_manifest(name) File "/usr/lib/python2.7/dist-packages/rospkg/rospack.py", line 211, in _load_manifest retval = self._manifests[name] = parse_manifest_file(self.get_path(name), self._manifest_name, rospack=self) File "/usr/lib/python2.7/dist-packages/rospkg/manifest.py", line 412, in parse_manifest_file _static_rosdep_view = init_rospack_interface() File "/usr/lib/python2.7/dist-packages/rosdep2/rospack.py", line 59, in init_rospack_interface lookup = _get_default_RosdepLookup(Options()) File "/usr/lib/python2.7/dist-packages/rosdep2/main.py", line 130, in _get_default_RosdepLookup verbose=options.verbose) File "/usr/lib/python2.7/dist-packages/rosdep2/sources_list.py", line 633, in create_default sources = load_cached_sources_list(sources_cache_dir=sources_cache_dir, verbose=verbose) File "/usr/lib/python2.7/dist-packages/rosdep2/sources_list.py", line 533, in load_cached_sources_list return parse_sources_data(cache_data, origin=cache_index, model=model) File "/usr/lib/python2.7/dist-packages/rosdep2/sources_list.py", line 388, in parse_sources_data raise InvalidData('line:\n\t%s\n%s' % (line, e), origin=origin) rosdep2.core.InvalidData: line: yaml https://raw.githubusercontent.com/ros... osx unsupported pickle protocol: 4 [spawn_urdf-4] process has died [pid 6224, exit code 1, cmd /opt/ros/kinetic/lib/gazebo_ros/spawn_model -file /home/toki/catkin_ws/src/ros_robotics/urdf/dd_robot.gazebo -urdf -model ddrobot __name:=spawn_urdf __log:=/home/toki/.ros/log/fb16499c-25d5-11e8-b86e-8056f2be489d/spawn_urdf-4.log]. log file: /home/toki/.ros/log/fb16499c-25d5-11e8-b86e-8056f2be489d/spawn_urdf-4*.log</module></module></module></module>
Some setup information would be useful: ROS and Gazebo versions of your and your friend's machines. And which operating system? There is this line in your traceback: "line: yaml https://raw.githubusercontent.com/ros... osx unsupported pickle protocol: 4 [spawn_urdf-4]" -> this might be a Python-related error. Which Python versions are running on your and your friend's computers? Type 'python --version' in the console to find out.
Tim Stadtmann gravatar imageTim Stadtmann ( 2018-03-14 02:53:04 -0500 )edit
