How to use AttachStaticModel function
asked 2018-04-27 06:48:02 -0600
I am implementing a simple robot with two links and one revolute joint. I want that the model would be able to attach a second model (a simple box) and move it . I am trying to use the AttachStaticModel function, but the model does not attach it. I have read that SetStatic function can be a problem, so i had simulated the four possibles cases. Can someone give me an example of how can i use the attach function or tell me where is the problem?
Thank you
#include "boost/bind.hpp"
#include "gazebo/gazebo.hh"
#include "gazebo/physics/physics.hh"
#include "gazebo/common/common.hh"
#include "stdio.h"
#include <fstream>
namespace gazebo
  class joint_c : public ModelPlugin
    this->model = _parent;
    this->world= this->model->GetWorld();
    this->mbox=this->world->GetModel("minibox");
    this->jointR1_ = this->model->GetJoint("r1");
    std::cout<<" \ntime \n"<<std::endl;
this->updateConnection = event::Events::ConnectWorldUpdateBegin(boost::bind(&joint_c::OnUpdate, this, _1));
  public: void OnUpdate(const common::UpdateInfo &_info)
    //Non static
    if(_info.simTime.Float()>5 && _info.simTime.Float()<15){
    this->mbox->SetStatic(false);
    this->model->SetStatic(false);
    this->model->AttachStaticModel(this->mbox,math::Pose(0,0,0.6,0,0,0));
        if(_info.simTime.Float()>10){
            this->jointR1_->SetVelocity(0, 0.5);
    //Second model static
    if(_info.simTime.Float()>15 && _info.simTime.Float()<25){
    this->mbox->SetStatic(true);
        if(_info.simTime.Float()>20){
            this->jointR1_->SetVelocity(0, -0.5);
    //First model static
    if(_info.simTime.Float()>25 && _info.simTime.Float()<35){
    this->model->SetStatic(true);
    link1->AttachStaticModel(this->mbox,math::Pose(0,0,0.6,0,0,0));
        if(_info.simTime.Float()>30){
    //Both static
    if(_info.simTime.Float()>35 && _info.simTime.Float()<45){
        if(_info.simTime.Float()>40){
std::cout<<_info.simTime.Float()<<" \ntime \n"<<std::endl;
    common::Time last_update_time_;
  private:
       physics::ModelPtr model;
       physics::ModelPtr mbox;
       physics::WorldPtr world;
       event::ConnectionPtr updateConnection;
   physics::JointPtr jointR1_;
  GZ_REGISTER_MODEL_PLUGIN(joint_c)
Hi, am having the same issue - trying to attach a static model to a non static. I have the correct parameters - not sure what is wrong (there are nor errors thrown). In fact, if you use the function correctly with a NON static model, you will get the error "[Err] [Model.cc:1310] AttachStaticModel requires a static model" ....
Dougie DeRosa gravatar imageDougie DeRosa ( 2019-09-25 10:35:41 -0600 )edit
