Custom plugins causes assertion error of boost
asked 2018-06-01 02:11:19 -0500
dnikitop gravatar image
Created a custom plugin to apply force to a link. When only one of these plugins are applied to the urdf, the system works fine. When two are applied to different links, this error pops up and gazebo does not open. Also use ros_control for motor actuation. This error happens even if that is disabled as well.
public: virtual void Load(physics::ModelPtr _parent, sdf::ElementPtr _sdf)
  this->model = _parent;
  this->link_name = _sdf->GetElement("BodyName")->Get<std::string>();
  this->link = model->GetLink(this->link_name);
  if(!ros::isInitialized())
    return;
  ros::Duration gazebo_period(model->GetWorld()->Physics()->GetMaxStepSize());
  // simulation iteration.
  this->rosNode.reset(new ros::NodeHandle(link_name));
  // central_pub = n.advertise<std_msgs::Float32>("force_node_out",10);
  ros::SubscribeOptions so =
       ros::SubscribeOptions::create<std_msgs::Float32>(
       "/" + link_name + "/for_cmd",
       1,
       boost::bind(&ModelPush::OnRosMsg, this, _1),
       ros::VoidPtr(), &this->rosQueue);
   this->rosSub = this->rosNode->subscribe(so);
  // Spin up the queue helper thread.
  this->rosQueueThread =
  std::thread(boost::bind(&ModelPush::QueueThread, this));
  this->updateConnection = event::Events::ConnectWorldUpdateEnd(
      boost::bind(&ModelPush::OnUpdate, this));
public:  void OnUpdate()
  this->link->AddRelativeForce(ignition::math::Vector3d(0,0,force));
The error given... C:\fakepath\GazeboError.png
answered 2018-06-02 10:52:11 -0500
You should check if this->link is not null, you could be asking for the wrong name, and then the program crashes when you try to access it on OnUpdate.
Asked: 2018-06-01 02:11:19 -0500
Seen: 55 times
Last updated: Jun 02 '18
