my model is not showing in gazebo
asked 2018-06-11 07:35:54 -0600
rohit18mittal gravatar image
updated 2018-06-11 11:52:31 -0600
my model is not showing under insert tab, here i am showing step by step procedure of what i have done
Step 1 I want test1 model to be shown up in gazebo C:\fakepath\Screenshot from 2018-06-11 17:54:57.png
Step 2 I have sdf file and config file, also .dae file in meshes folder C:\fakepath\Screenshot from 2018-06-11 17:58:15.png
Step 3 screen shot of config and sdf file C:\fakepath\Screenshot from 2018-06-11 17:59:49.png C:\fakepath\Screenshot from 2018-06-11 18:01:31.png
Step 4 Finally in step 4 when i open gazebo then under insert tab this is what i get C:\fakepath\Screenshot from 2018-06-11 18:02:29.png
answered 2018-06-11 11:57:09 -0600
Here are some problems I spotted:
  • The config file cannot have an arbitrary name, it must be called model.config, you're calling it camera.config
  • The root element of the .sdf file must be <model>, you currently have <world>
When you launch gazebo, run it in verbose mode so you can see error messages that should give you more clues:
gazebo --verbose
thanks for your reply, i will correct it
rohit18mittal gravatar imagerohit18mittal ( 2018-06-12 05:08:25 -0600 )edit
thanks a ton chapulina, my model is now showing in gazebo Thank you very much
rohit18mittal gravatar imagerohit18mittal ( 2018-06-12 05:52:46 -0600 )edit
Asked: 2018-06-11 07:35:54 -0600
Seen: 367 times
Last updated: Jun 11 '18
