How to get msgs::LogicalCameraImage timestamp?
asked 2018-06-22 09:05:36 -0500
federico.nardi gravatar image
Hi all,
I wrote an urdf for a diff-drive robot with a logical camera sensor.
To publish its messages over ROS I wrote a simple plugin:
#include "logical_camera_plugin.h"
using namespace gazebo;
using namespace std;
using namespace ros;
GZ_REGISTER_SENSOR_PLUGIN(LogicalCameraPlugin);
void LogicalCameraPlugin::Load(sensors::SensorPtr _sensor, sdf::ElementPtr _sdf){
  // Get the parent sensor.
  this->parentSensor = std::dynamic_pointer_cast<sensors::LogicalCameraSensor>(_sensor);
  // Make sure the parent sensor is valid.
  if (!this->parentSensor){
    gzerr << "LogicalCameraPlugin requires a LogicalCameraSensor.\n";
    return;
  // Connect to the sensor update event.
  this->updateConnection = this->parentSensor->ConnectUpdated(std::bind(&LogicalCameraPlugin::OnUpdate, this));
  // Make sure the parent sensor is active.
  this->parentSensor->SetActive(true);
  nh = new ros::NodeHandle("~");
  image_pub = nh->advertise<lucrezio_simulation_environments::LogicalImage>("logical_camera_image", 1, true);
void LogicalCameraPlugin::OnUpdate(){
  msgs::LogicalCameraImage logical_image;
  lucrezio_simulation_environments::LogicalImage msg;
  logical_image = this->parentSensor->Image();
  gazebo::rendering::ScenePtr scene = gazebo::rendering::get_scene();
  if (!scene || !scene->Initialized())
    return;
  msg.header.stamp = ros::Time::now();
  msg.header.frame_id = "logical_camera_link";
  this->image_pub.publish(msg);
My only concern was:
Is it possible to get from the msgs::LogicalCameraImage a timestamp?
Because, right now, I'm giving ros::Time::now() to the ROS message and I guess this is not the right solution.
Thanks.
answered 2018-06-22 09:46:18 -0500
updated 2018-06-22 10:19:11 -0500
That LogicalCameraImage message is not stamped (i.e. it doesn't have a header), so I think it's not possible to know the exact time from the message itself.
I think you're doing the right thing by connecting to the ConnectUpdated event. From that callback, I think you'll get the correct time for when the last image message was generated with:
auto lastUpdateTime = this->parentSensor->LastUpdateTime();
the LogicalCameraPlugin is a `SensorPlugin`, I'm afraid I didn't get what you mean!
federico.nardi gravatar imagefederico.nardi ( 2018-06-22 10:01:55 -0500 )edit
Ah sorry, you're right, I woke up too early to watch football. Updating the answer.
chapulina gravatar imagechapulina ( 2018-06-22 10:11:09 -0500 )edit
Thanks, I'll try! "Come on Iceland"!!!!!
federico.nardi gravatar imagefederico.nardi ( 2018-06-22 10:27:47 -0500 )edit
It doesn't compile because lastUpdateTime is protected within that context
federico.nardi gravatar imagefederico.nardi ( 2018-06-22 10:30:54 -0500 )edit
my fault, LastUpdateTime should be called!
federico.nardi gravatar imagefederico.nardi ( 2018-06-22 10:35:55 -0500 )edit
Asked: 2018-06-22 09:05:36 -0500
Seen: 84 times
Last updated: Jun 22 '18
