Using Gazebo without ROS?
asked 2018-07-24 08:53:16 -0600
Mr Seppersburg gravatar image
Hi I have a question. After going through the documentation of Gazebo I am a little frustrated. I really like the sim in ROS but for my current project I can not use ROS.
What I want to do is: Visualize a real robot in a 3D visualization together with additional stuff (like a "ghost" robot showing the goal config, little spheres indicating goal position, frames, etc). So basically I want a lightweight RViz without using ROS.
The documentation links back to ROS all the time so I don't really know if I can use Gazebo.
My questions now are:
  1. Can I simply load urdfs into the simulator (like with pybullet)? 1a. If I can only load SPFs, is there a conversion tool? (Somehow when Gazebo is used in ROS, there are also only URDFs/Urdf-macros used.)
  2. Can I update robot joints continously in a program without ROS (and how?)
  3. Can I disable all collision detection (basically the actual phys. simulation), so I can spawn robots into each other and don't have delayed actuation due to inertia?
Any help would be much appreciated. I think Gazebo should be able to do everything I want, I just don't know how to get there.
2
answered 2018-07-25 10:51:34 -0600
updated 2018-07-25 11:29:35 -0600
Yes, Gazebo is intended to work as a standalone robot simulator / visualizer.
This may be possible via Gazebo Plugins in some of the later version of Gazebo.
See: http://answers.gazebosim.org/question...
and: https://ignitionrobotics.org/home
Have you looked through the Gazebo Tutorials? Many of them cover using Gazebo without ROS.
1) Can I simply load urdfs into the simulator (like with pybullet)?
Yes.
1a) If I can only load SDFs, is there a conversion tool? (Somehow when Gazebo is used in ROS, there are also only URDFs/Urdf-macros used.)
You can load URDFs directly into Gazebo without ROS, but you can also convert a URDF files into a SDF file, using
gz sdf -p my_urdf.urdf > my_sdf.sdf
2) Can I update robot joints continously in a program without ROS (and how?)
Yes, you can do this via a custom Gazebo Plugin.
See: http://gazebosim.org/tutorials?cat=gu...
and: http://gazebosim.org/tutorials?tut=se...
and: https://answers.ros.org/question/2330...
3) Can I disable all collision detection (basically the actual phys. simulation), so I can spawn robots into each other and don't have delayed actuation due to inertia?
Yes.
and: https://answers.ros.org/question/2187...
Thanks so far, I will look into all the provided links when I have found time. Very thorough answer!
Mr Seppersburg gravatar imageMr Seppersburg ( 2018-07-26 01:59:23 -0600 )edit
Asked: 2018-07-24 08:53:16 -0600
Seen: 353 times
Last updated: Jul 25 '18
