Joint world pose for each step of simulation
asked 2018-08-13 23:09:43 -0600
jc gravatar image
updated 2018-08-13 23:10:23 -0600
How would I obtain joint world pose data for each step in a simulation? I have a model plugin that can get the joint position before the simulation is run, but how do I get the joint world pose for each simulation step?
Thanks!
2
answered 2018-08-14 04:04:54 -0600
Veztak gravatar image
If you have a function that gets the joint world pose before simulation i assume you are calling it in the Load() function of the plugin. You can then, in the same way, call your function in the OnUpdate() loop. By my understanding, that gets called every iteration.
You can find a more detailed description at: Sensor OnUpdate
Thanks for the help! Outside of the tutorials where is this documented?
jc gravatar imagejc ( 2018-08-14 11:02:31 -0600 )edit
answered 2018-08-14 11:07:41 -0600
jc gravatar image
If anyone is interested, this tutorial helped me.
Add this to the Load() function:
      std::bind(&ModelPush::OnUpdate, this));
And delcare this variable:
And finally add the OnUpdate() function:
    public: void OnUpdate()
Asked: 2018-08-13 23:09:43 -0600
Seen: 145 times
Last updated: Aug 14 '18
