ROS subscriber not using callback function
asked 2018-08-22 10:26:03 -0500
MRhinelander gravatar image
 #include <boost/bind.hpp>
#include <gazebo/gazebo.hh>
#include <gazebo/math/gzmath.hh>
#include <gazebo_msgs/ModelStates.h>
#include <stdio.h>
#include <ros/ros.h>
#include <std_msgs/String.h>
#include <string>
void model_states_callback(const gazebo_msgs::ModelStates::ConstPtr& msg)
    ROS_INFO("I heard the model state!");
namespace gazebo
  class kiwi_pos : public ModelPlugin
    public: kiwi_pos() : ModelPlugin()
    public: void Load(physics::ModelPtr _parent, sdf::ElementPtr _sdf)
            if(!ros::isInitialized())
        ROS_FATAL_STREAM("A ROS node for Gazebo has not been initialized, unable to load plugin. "
        << "Load the Gazebo system plugin 'libgazebo_ros_api_plugin.so' in the gazebo_ros package)");
        return;
            ROS_INFO("KIWI POSITION PLUGIN LOADED");
      this->model = _parent;
      // simulation iteration.
          boost::bind(&kiwi_pos::OnUpdate, this, _1));
            ros::NodeHandle n;
            ros::Subscriber sub = n.subscribe("gazebo/model_states",1000,model_states_callback);
            //ros::spin();
    public: void OnUpdate(const common::UpdateInfo & /*_info*/)
    // Pointer to the model
  GZ_REGISTER_MODEL_PLUGIN(kiwi_pos)
Here is my code, I am simply trying to listen in on the model states topic and publish a confirmation when I hear it. When I run the simulation I get the PLUGIN LOADED ROS_INFO but nothing else is outputted.
answered 2018-08-31 03:10:43 -0500
wentz gravatar image
I think you need to keep the NodeHandle and the Subscriber. Saving them as class vars should fix the problem.
Asked: 2018-08-22 10:26:03 -0500
Seen: 566 times
Last updated: Aug 31 '18
