How to add ignition msgs to ROS?
asked 2018-09-24 12:11:48 -0600
kumpakri gravatar image
updated 2018-09-24 12:12:21 -0600
I want to use gazebo plugins that use ignition messages in ROS project. I have installed libignition-msgs* libraries, but when I list all the types of messages in ROS with this command $ rosmsg list There is no ignition type of message.
How can I load the ignition-msgs into ROS?
answered 2018-10-02 12:08:13 -0600
ROS uses its own message description; Ignition Messages is a separate format.
All ROS tools will only handle ROS messages, you'll need Ignition tools to use Ignition messages.
There is a Gazebo plugin ContainPlugin that publishes those ignition messages to the topic /contain. Does that mean my ROS node won't be able to subscribe to those topics?
kumpakri gravatar imagekumpakri ( 2018-10-03 02:36:51 -0600 )edit
Correct. You can use an Ignition node to subscribe to the message and then convert it to ROS if necessary.
chapulina gravatar imagechapulina ( 2018-10-03 08:58:24 -0600 )edit
Asked: 2018-09-24 12:11:48 -0600
Seen: 125 times
Last updated: Oct 02 '18
