How to control publish rate in ROS-enabled plugins? [closed]
asked 2013-03-25 10:50:56 -0600
Boris gravatar image
Are there any standard option for this? It used to be <updateRate> parameter, but it seems not to work anymore. Although there is <update_rate>, it works only for sensor plugins.
At the moment my model plugin publishes data in OnUpdate() function without any additional time control.
Should I publish the data in parallel thread and achieve necessary rate with something like ros::Rate::sleep() or there is a better option?
Thanks
edit retag flag offensive reopen merge delete
Closed for the following reason the question is answered, right answer was accepted by scpeters
close date 2014-04-23 12:38:01.211476
answered 2013-03-25 12:43:34 -0600
AndreiHaidu gravatar image
updated 2013-03-26 02:58:36 -0600
I don't think there is a dedicated function for this, but you can easily use it like this:
// set the update rate (you can also set it as a parameter from the sdf file)
this->updateRate = common::Time(0, common::Time::SecToNano(0.75));
// initialize the prevUpdateTime
this->prevUpdateTime = common::Time::GetWallTime();
void PluginClass::OnUpdate()
  if (common::Time::GetWallTime() - this->prevUpdateTime < this->updateRate)
    return;
========UPDATE, HOW TO GET THE PARAMETER EXAMPLE=========
in the sdf file:
<plugin name='plugin_name' filename='libplugin_name.so'>
    <sdf_parameter_update_rate>69.0</sdf_parameter_update_rate>
in the plugin:
void PluginName::Load(physics::ModelPtr _parent, sdf::ElementPtr _sdf)
double param_update_rate;
if (!_sdf->HasElement("sdf_parameter_update_rate"))
    // if parameter tag does NOT exist
    std::cout << "Missing parameter <sdf_parameter_update_rate> in PluginName, default to 0" << std::endl;
    param_update_rate = 0;
    // if parameter tag exists, get its value
else param_update_rate = _sdf->GetElement("sdf_parameter_update_rate")->GetValueDouble();
and then you use this param_update_rate in setting the updateRate value:
this->updateRate = common::Time(0, common::Time::SecToNano(param_update_rate));
Cheers, Andrei
Thanks, will give it a try. Does this->updateRate load from <updateRate> or <update_rate> parameter?
Boris gravatar imageBoris ( 2013-03-25 23:46:14 -0600 )edit
you set it in the code yourself ( common::Time(0, common::Time::SecToNano(0.75)); ), or you can load it as a parameter from the sdf file, I will update the answer to see how that is done
AndreiHaidu gravatar imageAndreiHaidu ( 2013-03-26 02:48:37 -0600 )edit
Yeah, I know how to get parameters from SDF, but thanks for the code snippets anyway! I was wondering if some of the legacy parameters that use to load automagically are still persist... Looks like not.
Boris gravatar imageBoris ( 2013-03-26 08:51:50 -0600 )edit
Finally added this functionality to my plugin. The only concern is the `SecToNano()` function, see details [here](http://answers.gazebosim.org/question/2334/confusion-with-commontimesectonano/).
Boris gravatar imageBoris ( 2013-04-11 01:19:30 -0600 )edit
Asked: 2013-03-25 10:50:56 -0600
Seen: 3,915 times
Last updated: Mar 26 '13
