Control Model Tutorial: Sensor isn't attached
asked 2013-03-25 19:35:19 -0500
Ben B gravatar image
updated 2013-03-26 12:37:05 -0500
I'm going through the Control Model tutorial. Part of the plugin displays the minimum distance sensed by a ray sensor. Unfortunately, it's perpetually displaying min_range = 9.500. I think the sensor isn't travelling with the box, because when I change the initial pose of the box, the 9.500 value changes to something else and stays put.
My understanding was that having the sensor inside of <joint></joint> tags was supposed to keep it attached. Am I wrong? How do I attach it?
I'm wondering if something in Gazebo is configured wrong because running this tutorial up to and including the gztopic echo /gazebo/default/box/link/my_contact doesn't produce anything other than
$ gztopic echo /gazebo/default/box/link/my_contact
Msg Waiting for master
Msg Publicized address: 142.103.111.179
answered 2013-03-27 15:00:46 -0500
GAugusto gravatar image
updated 2013-03-27 19:10:36 -0500
hi. try to check if each ray is measuring correctly.
edit the plugin to:
      this->model->SetLinearVel(math::Vector3(0, 0, 0)); //so it does not move
and add this below it
      // console output
      static int rgcount =0;
      rgcount ++;
      if(rgcount>=2000)
         rgcount = 0;
         float r0 = this->raysensor->GetRange(0); //index 0
         float r90 = this->raysensor->GetRange(90); //index 90
         float r180 = this->raysensor->GetRange(179); //index 179
         printf("0deg:   %3.3f \n90deg:  %3.3f \n180deg: %3.3f \n\n", r0, r90, r180);
then manualy put/move cubes at these angles changing distances, see if the values match or if they give the same number as before. also move the box with the sensor manualy around to see if the sensor moves with the box.
edit: index 180 -> 179
I think index 180 should be index 179. Anyway, no change. I'm getting 30, 9.5, and 30.
Ben B gravatar imageBen B ( 2013-03-27 16:09:19 -0500 )edit
yes, indeed it should be 179 (i used to use 181samples). well the ranges seam correct. did moving the box manualy changed the range values? if not then the sensor is not moving with the model, wich is wierd because the model description seams correct.
GAugusto gravatar imageGAugusto ( 2013-03-27 19:04:18 -0500 )edit
Unfortunately, the values stayed the same.
Ben B gravatar imageBen B ( 2013-03-27 19:18:56 -0500 )edit
that is very strange,the sensor is really unattached from the model. i just finished redoing the tutorial and it worked, tho im using gazebo1.4 the sdf is still 1.3 :/ can you see the rays (blue field) moving with the box?
GAugusto gravatar imageGAugusto ( 2013-03-27 19:53:32 -0500 )edit
I don't see the blue rays at all.
Ben B gravatar imageBen B ( 2013-03-27 19:58:35 -0500 )edit
then probably there was a bug/accident during the installation. unfortunately i cant help you more. :( last resource scenario reinstall gazebo, BUT make a backup of your .bashrc file (gedit ~/.bashrc) just to be safe before you reinstall.
GAugusto gravatar imageGAugusto ( 2013-03-27 20:13:33 -0500 )edit
Thanks for trying, GAugusto. Unfortunately, I've tried reinstalling. First I had it installed from a repo, then I tried from source. I've also reproduced this error on fresh install on another computer.
Ben B gravatar imageBen B ( 2013-03-28 12:13:09 -0500 )edit
answered 2013-03-25 23:40:34 -0500
Boris gravatar image
According to SDF 1.3:
A plugin is a dynamically loaded chunk of code. It can exist as a child of world, model, and sensor.
You can see also that there are no <plugin> tags inside <joint> section. So you have to move it to <model> section as it done in tutorial.
Hi there, my code is just like in the tutorial. The plugin is within the model tags. And the ray sensor is within the joint tags.
Ben B gravatar imageBen B ( 2013-03-26 09:43:24 -0500 )edit
you mean within the <link> tags, right? that's hot it is in the example
AndreiHaidu gravatar imageAndreiHaidu ( 2013-03-26 10:21:25 -0500 )edit
My bad. You're right. I should've said: It's within the <link> tags.
Ben B gravatar imageBen B ( 2013-03-26 11:23:53 -0500 )edit
answered 2013-03-26 03:33:55 -0500
I am not sure because I did not have time to test it, but I noticed in the code the following line may be wrong, this could be the reason you always get a constant for the range value.
double min_range = this->raysensor->GetRangeMax();
notice how 'min_range' variable gets the max range value from the function 'GetRangeMax()'
And is the plugin doing what is supposed to do? 'You should see the box move slowly towards the wall.' ?
Cheers, Andrei
Hi Andrei, I think I interpreted it like you did at first. But I think the get range max function is actually the max range of the sensor is actually the furthest it can sense. So it makes sense that it defaults to this when it has no other reading.
Ben B gravatar imageBen B ( 2013-03-26 09:47:16 -0500 )edit
Also, the box does move.
Ben B gravatar imageBen B ( 2013-03-26 09:55:02 -0500 )edit
And does it stop when it is close to the wall? If it does, that means the range changes, as it only stops when the range is below 1.0 : if(min_range <= 1.0) \n vel = 0.0;
AndreiHaidu gravatar imageAndreiHaidu ( 2013-03-26 10:26:44 -0500 )edit
It only stops when hits the wall. The min_range reports 9.5 from when it starts and continues to report 9.5 even when it's running into the wall.
Ben B gravatar imageBen B ( 2013-03-26 11:24:52 -0500 )edit
Okey, I also tried the exapmple, and for me it worked, I am using gazebo 1.5 from source, what is your version?
AndreiHaidu gravatar imageAndreiHaidu ( 2013-03-26 12:06:48 -0500 )edit
I'm using 1.5.0 installed from the repo. The only change I've made to the tutorial is that mine is all installed in a different directory. Though I'm not getting any errors about missing anything. I'll try the directory mentioned in the tutorial.
Ben B gravatar imageBen B ( 2013-03-26 12:14:09 -0500 )edit
Still no dice.
Ben B gravatar imageBen B ( 2013-03-26 12:21:31 -0500 )edit
Andrei, can you see the rays from the sensor? Also, do you get this error: "Error [Events.hh:141] Events::ConnectWorldUpdateStart is deprecated in v 1.5.0. Please use Events::ConnectWorldUpdateBegin" ? I've tried making the change the error suggests. The error goes away, but it still doesn't work.
Ben B gravatar imageBen B ( 2013-03-26 12:24:38 -0500 )edit
Yes I can see the rays, I also got the error and it worked with it, so I did not change it to Events::ConnectWorldUpdateBegin.
AndreiHaidu gravatar imageAndreiHaidu ( 2013-03-26 12:31:44 -0500 )edit
Dang. I can't seem to get any of the sensors to report anything. I've updated the question to reflect that the contact sensor doesn't work either.
Ben B gravatar imageBen B ( 2013-03-26 16:29:41 -0500 )edit
Asked: 2013-03-25 19:35:19 -0500
Seen: 546 times
Last updated: Mar 27 '13
