Apply normal map shader
asked 2018-10-18 03:21:00 -0500
I noticed in the SDF specification one can add a <shader> tag with type normal_map_tangentspace to a <material> tag. But when I try to load my world file in gazebo 9 (also tried it in 7), the last output I get in the console is waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting.... It will wait forever.
I also made sure that the gazebo_model_path is set up correctly in my package.xml, so the texture file specified in the <normal_map> child tag should get found. It works at least for meshes and material scripts. Here is a snippet from my world file:
    <model name="model">
                    <mesh>
                        <uri>model://mesh.dae</uri>
                    </mesh>
                    <shader type="normal_map_tangentspace">
                        <normal_map>model://materials/textures/Normal.png</normal_map>
                    </shader>
                    <script>
                        <uri>model://materials/scripts</uri>
                        <name>Material</name>
                    </script>
Does anyone have experience with this and knows what I'm missing?
Thanks in advance, David
That console message seems to be coming from ROS and not related to Gazebo's rendering.
chapulina gravatar imagechapulina ( 2018-10-18 12:37:12 -0500 )edit
Also, I'd double-check that you're referring to the correct resource locations, usually you'd have the model name after `model://`
chapulina gravatar imagechapulina ( 2018-10-18 12:38:12 -0500 )edit
I'm pretty confident that the path is correct. I've tested it by using it in the mesh uri as well. The mesh got found after I copied it to the same location as my normal map image. And I double checked its name a 1000 times. I had the hope that the last output would give someone a hint where gazebo or ROS seem to encounter a problem. Sadly I have no other feedback, since there is no exception being thrown or anything. It just works fine as soon I comment out the <shader> tag in my world file.
D4KU gravatar imageD4KU ( 2018-10-22 07:59:07 -0500 )edit
answered 2018-12-20 11:33:50 -0500
D4KU gravatar image
I figured it out. I copied 'normal_map_tangentspace' from the SDF specification, but it's a typo. It must say 'normal_map_tangent_space'. That little thing has cost me hours...
Asked: 2018-10-18 03:21:00 -0500
Seen: 591 times
Last updated: Dec 20 '18
