why my wheel joint is spin,when I use Joint::setposition to control it?
asked 2018-10-25 00:29:50 -0500
xianxjm gravatar image
updated 2018-10-26 06:37:07 -0500
How to use Joint::setposition to control a joint? Is there a doc or example? I know how to control joint by SetPositionPID,but this method is not very good performance, the wheel movement is not very accurate.
Thanks advance!
code like this :
void TestS::Update(const common::UpdateInfo &iInfo){
        m_ptrModel->GetJoint("left_wheel_joint")->SetForce(0,3800);
        m_ptrModel->GetJoint("left_wheel_joint")->GetChild()->SetEnabled(true);
        m_ptrModel->GetJoint("left_wheel_joint")->GetParent()->SetEnabled(true);
        m_ptrModel->GetJoint("right_wheel_joint")->SetForce(0,3800);
        m_ptrModel->GetJoint("right_wheel_joint")->GetChild()->SetEnabled(true);
        m_ptrModel->GetJoint("right_wheel_joint")->GetParent()->SetEnabled(true);
        m_ptrModel->GetJoint("left_wheel_joint")->SetPosition(0,update);
        m_ptrModel->GetJoint("right_wheel_joint")->SetPosition(0,update);
       update++;
can you post relevant parts of your code? Namely transmission tags and controller configuration files.
kumpakri gravatar imagekumpakri ( 2018-10-25 06:28:06 -0500 )edit
@kumpakri I post my code , please help~ if you have anothor way to control the precise movement of the wheels,Thanks for sharing!
xianxjm gravatar imagexianxjm ( 2018-10-26 06:40:38 -0500 )edit
answered 2018-11-02 08:32:09 -0500
wentz gravatar image
Because you are also setting a force to the joints causing them to rotate.
Have you ever tried? Without setting a force to the joints,the situation is worse!!!
xianxjm gravatar imagexianxjm ( 2018-11-23 04:20:03 -0500 )edit
Asked: 2018-10-25 00:29:50 -0500
Seen: 7,033 times
Last updated: Nov 02 '18
