Gazebo Baxter simulation catkin-make failed
asked 2018-11-03 14:23:47 -0600
Hi! I want to install baxter gazebo simulation on my laptop. I am currently using ROS kinetic and Gazebo 7. When I did 'catkin-make', I get the following error:
 [ 91%] Built target baxter_gazebo_ros_control
[ 92%] Built target baxter_sim_kinematics
[ 93%] Built target kinematics
[ 94%] Built target baxter_emulator
//usr/lib/x86_64-linux-gnu/libapr-1.so.0: undefined reference to `uuid_generate@UUID_1.0'
collect2: error: ld returned 1 exit status
baxter_simulator/baxter_sim_io/CMakeFiles/baxter_sim_io.dir/build.make:308: recipe for target '/home/haowei/ros_ws/devel/lib/baxter_sim_io/baxter_sim_io' failed
make[2]: *** [/home/haowei/ros_ws/devel/lib/baxter_sim_io/baxter_sim_io] Error 1
CMakeFiles/Makefile2:4429: recipe for target 'baxter_simulator/baxter_sim_io/CMakeFiles/baxter_sim_io.dir/all' failed
make[1]: *** [baxter_simulator/baxter_sim_io/CMakeFiles/baxter_sim_io.dir/all] Error 2
Makefile:138: recipe for target 'all' failed
make: *** [all] Error 2
Invoking "make -j4 -l4" failed
Any suggestions are appreciated. Thanks!
I am using Ubuntu 16.04 and I followed the tutorial here
Can you post the steps needed to reproduce your problem, including OS type and version? Also include links to documentation and tutorials that you were following.
nkoenig gravatar imagenkoenig ( 2018-11-05 15:35:23 -0600 )edit
I'm also having exact same problem here. Would you plz share me if any updates?
coh gravatar imagecoh ( 2018-11-07 03:44:46 -0600 )edit
answered 2018-11-12 10:42:27 -0600
coh gravatar image
Just to share the solution I could get from another website: https://github.com/ROBOTIS-GIT/turtle...
Thanks! Does it mean Anaconda contradict with our package? Is the solution working?
wpiHaowei gravatar imagewpiHaowei ( 2018-11-13 15:36:59 -0600 )edit
Yes. In my case, I could build successfully after I remove conda related paths from PATH and LD_LIBRARY_PATH.
coh gravatar imagecoh ( 2018-11-15 05:03:50 -0600 )edit
answered 2018-11-05 15:50:06 -0600
You might be running into version problems. I think the baxter simulation environment requires Ubuntu 14.04: http://sdk.rethinkrobotics.com/wiki/W...
You could try setting up a Docker container.
Thanks! But there is an instruction on how to install the simulation based on ROS kinetic. As far as I know kinetic is only available on Ubuntu 16.
wpiHaowei gravatar imagewpiHaowei ( 2018-11-05 15:54:54 -0600 )edit
2 followers
Asked: 2018-11-03 14:23:47 -0600
Seen: 719 times
Last updated: Nov 12 '18
