i keep having this error when i try to launch my urdf model
asked 2018-11-19 21:10:16 -0600
mohamed ashraf gravatar image
REQUIRED process [gazebo-4] has died! process has died [pid 9348, exit code 255, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver /home/mohamed/catkin_ws/src/m3a_pro/ctcv_gazebo/worlds/ctcv.world __name:=gazebo __log:=/home/mohamed/.ros/log/1e2530e4-ec71-11e8-89ca-a088699ada62/gazebo-4.log]. log file: /home/mohamed/.ros/log/1e2530e4-ec71-11e8-89ca-a088699ada62/gazebo-4*.log Initiating shutdown!
my URDF FILE <robot name="robotcraft2018">
<material name="black"> <color rgba="0 0 0 1"/> </material> <material name="white"> <color rgba="1 1 1 1"/> </material> <material name="red"> <color rgba="0.8 0 0 1"/> </material> <material name="green"> <color rgba="0 1 0 1"/> </material> <material name="purple"> <color rgba="0.5 0 0.5 1"/> </material> <material name="transparent"> <color rgba="0.6 0.6 0.6 0.35"/> </material>
<link name="base_link"> <visual> <origin rpy="0 0 3.14159265359" xyz="0.03 -0.005 -0.09"/> <geometry> <mesh filename="package://ctcv_gazebo/mesh/Black.stl" scale="0.001 0.001 0.001"/> </geometry> <material name="black"/> </visual>
<collision> <origin rpy="0 0 3.14159265359" xyz="0.03 -0.005 -0.09"/> <geometry> <mesh filename="package://ctcv_gazebo/mesh/Black.stl" scale="0.001 0.001 0.001"/> </geometry> </collision>
    <mass value="350"/>
    <inertia ixx="2.0" ixy="0.0" ixz="0.0" iyy="2.0" iyz="0.0" izz="2.0"/>
<gazebo reference="base_link"> <material>Gazebo/Black</material> </gazebo>
<link name="bottom_base"> <visual> <geometry> <mesh filename="package://ctcv_gazebo/mesh/White.stl" scale="0.001 0.001 0.001"/> </geometry> <origin rpy="0 0 3.14159265359" xyz="0 -0.005 -0.11"/> <material name="white"/> </visual> <collision> <origin rpy="0 0 3.14159265359" xyz="0 -0.005 -0.11"/> <geometry> <mesh filename="package://ctcv_gazebo/mesh/White.stl" scale="0.001 0.001 0.001"/> </geometry> </collision>
    <mass value="350"/>
<gazebo reference="bottom_base"> <material>Gazebo/White</material> </gazebo>
<link name="acrylic_base"> <visual> <geometry> <mesh filename="package://ctcv_gazebo/mesh/Transparent.stl" scale="0.001 0.001 0.001"/> </geometry> <origin rpy="0 0 3.14159265359" xyz="0 -0.005 -0.145"/> <material name="transparent"/> </visual> <collision> <origin rpy="0 0 3.14159265359" xyz="0 -0.005 -0.145"/> <geometry> <mesh filename="package://ctcv_gazebo/mesh/Transparent.stl" scale="0.001 0.001 0.001"/> </geometry> </collision>
    <mass value="350"/>
<gazebo reference="acrylic_base"> <material>Gazebo/GreyTransparent</material> </gazebo>
<link name="arduino"> <visual> <geometry> <mesh filename="package://ctcv_gazebo/mesh/Green.stl" scale="0.001 0.001 0.001"/> </geometry> <origin rpy="0 0 3.14159265359" xyz="0 -0.005 -0.17"/> <material name="green"/> </visual> <collision> <origin rpy="0 0 ... (more)
Can you trying running gazebo with the `--verbose` flag? The output of that might provide more information. If you're using a launch you'll have to modify the args attribute of the gazebo node.
azeey gravatar imageazeey ( 2018-11-20 16:59:23 -0600 )edit
