Pose of Collision entity
asked 2013-03-28 05:12:59 -0600
Max Stähr gravatar image
I am trying to retrieve the current Pose of all Collision entities. However I just can retrieve the initial Pose before starting the physics engine. The complete plugin code is pasted below.
include <boost bind.hpp=""> include <gazebo.hh> include <physics physics.hh=""> include <common common.hh=""> include <stdio.h>
using namespace std;
namespace gazebo
  class ModelPush : public ModelPlugin
      this->model = _parent;
      //frame
      frame=0;
      // simulation iteration.
          boost::bind(&ModelPush::OnUpdate, this, _1));
    public: void OnUpdate(const common::UpdateInfo & /*_info*/)
      // Apply a small linear velocity to the model.
      std::cout << "collision test" << std::endl;
      system("clear");
      cout << "frame\t" << frame << endl;
      frame = frame +1;
      physics::Link_V links = model->GetLinks();
      physics::Collision_V colls;
      for (unsigned int i = 0; i < links.size(); i++) {
          cout << links[i]->GetName() << "\t\t" <<links[i]->GetWorldPose() << endl;
          colls = links[i]->GetCollisions();
          for(unsigned i=0; i<colls.size(); i++)
              colls[i]->Update();
              cout << colls[i]->GetName() << "\t\t" << colls[i]->GetWorldPose() << endl;
    // Pointer to the model
    // Frame counter
    private: unsigned int frame;
  GZ_REGISTER_MODEL_PLUGIN(ModelPush)
Can anyone help? What am I doing wrong?
answered 2013-03-28 06:50:17 -0600
there is a litte missunderstanding. I don't want to detect a contact between the the collision entities, rather I would like to know the current pose if the collision entity at each time step. I can manage to retrieve the current Pose of each link but not of any collision geometry...
Cheers Max
Oh sorry, so you are saying you get a constant value all the time? Is the object moving? Could you also post your sdf file?
AndreiHaidu gravatar imageAndreiHaidu ( 2013-03-28 07:24:41 -0600 )edit
Hi, I solved the problem myself. The WordPose of the corresponding Link is updated. By aggregating the relative Collision pose with the WorldLinkPose I can retrieve the WorldCollisionPose. However, it seems to be a bug in the Collision Code. The WorldPose of collision entities is not updated at runtime.
Max Stähr gravatar imageMax Stähr ( 2013-04-02 01:30:59 -0600 )edit
Max Stähr gravatar imageMax Stähr ( 2013-04-02 01:31:03 -0600 )edit
answered 2013-03-28 05:56:48 -0600
The way 'OnUpdate' is called on every world update, another function ('onContact') will be called when a collision is detected. Here is the main idea:
// set the collision you wish to check
physics::CollisionPtr collision = this->model->GetLink("link_name")->GetCollision("collision_name");
// during a collision the 'onContact' function will be called every update step
event::ConnectionPtr connection = collision->ConnectContact(boost::bind (&ModelPush::onContact, this, _1, _2));
// the 'onContact' function
void ModelPush::onContact(const std::string &_collisionName, const physics::Contact &_contact)
// do what you need with the contact
Here you can find more about physics::Contact.
If you have any trouble implementing it, let me know.
Cheers, Andrei
2 followers
Asked: 2013-03-28 05:12:59 -0600
Seen: 4,716 times
Last updated: Mar 28 '13
