Gazebo uses exactly half of the cpu
asked 2018-11-21 07:38:57 -0500
firesurfer gravatar image
Hi, I'm using gazebo 9 (the version that comes with ros melodic) in combination with ros. I'm simply loading a ground plane together with some hexapod models.
I'm wondering why gazebo generates a cpu load of exactly half the maximum possible load.
I'd expect it to use at least one core at full load but instead it uses all 4 (or 6 cores on another computer) at just half the maximum load.
Perhaps someone could give me a hint if this is intended behaviour or if I misconfigurated something?
Thanks in advance
Its basically the same on my system (depending on the other programs i'm using). Guess that's the multi threading used by gazebo.
wentz gravatar imagewentz ( 2018-11-22 02:42:30 -0500 )edit
