Gazebo9 hangs on "Preparing Your World..." on macOS Mojave 10.14.1
asked 2018-12-05 17:42:38 -0600
variable gravatar image
updated 2018-12-10 10:59:22 -0600
I seemed to have solved the GUI scaling issue by installing the latest version of qt (5.12.0) but now Gazebo hangs at preparing your world (for hours). It doesn't seem to be downloading any models, /usr/local/share/gazebo-8/models only contains ground_plane and sun. I've tried manually copying all the model folders there but it doesn't help.
This is on both Gazebo8 and Gazebo9
~ gazebo --verbose
Gazebo multi-robot simulator, version 8.6.0
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Connected to gazebo master @ http://XXX.X.X.X:XXXX
[Msg] Publicized address: XX.XX.XX.XX
[Wrn] [GuiIface.cc:117] Failed to get QCocoaScreen for NSObject(0x0)
For me the workaround has been so far to switch between Qt 5.12.0 for RViz and 5.11.2 for Gazebo where the UI is overscaled but kind of usable anyway.
Danylo gravatar imageDanylo ( 2018-12-11 04:46:49 -0600 )edit
I see others are aware of it and working on it here: https://bitbucket.org/osrf/gazebo/issues/2531/gazebo-gui-rendering-is-scaled
variable gravatar imagevariable ( 2018-12-12 11:28:19 -0600 )edit
FYI, I am getting the same problem.
snogar gravatar imagesnogar ( 2018-12-14 15:07:51 -0600 )edit
Did you see my answer that minimizing the window fixes it?
variable gravatar imagevariable ( 2018-12-14 20:44:03 -0600 )edit
answered 2018-12-14 15:45:42 -0600
Minimizing the window and opening it back up fixes the issue. Sounds like there's a bug fix already submitted.
3 followers
Asked: 2018-12-05 17:42:38 -0600
Seen: 127 times
Last updated: Dec 14 '18
