Cannot install -- unmet dependencies -Ubuntu 18.04 using step x step tutorial
asked 2018-12-12 10:22:24 -0500
kenden gravatar image
updated 2018-12-12 12:11:35 -0500
chapulina gravatar image
Output:
beagle@beaglebone:~$ sudo apt install gazebo9
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 gazebo9 : Depends: gazebo9-common (= 9.4.1-1~bionic) but it is not going to be installed
           Recommends: gazebo9-plugin-base but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Have you tried installing the dependencies first? `sudo apt install gazebo9-common` `sudo apt install gazebo9-plugin-base`
chapulina gravatar imagechapulina ( 2018-12-12 12:13:00 -0500 )edit
Yes. Can’t get gazebo-common wbecause it depends on gazebo-base then can’t get gazebo base because it depends on gazebo9. Installed aptitude for the added help in resolving dependencies. That seemed to help until it didn’t. I thought hat it might be my setup but had help from another who was able to replicate the problem on a different system.
kenden gravatar imagekenden ( 2018-12-12 16:55:12 -0500 )edit
