Simulating Springs
asked 2012-11-14 00:23:57 -0500
mdedonato gravatar image
I am looking to simulate a spring on a rotational joint in Gazebo. My goal would be to have an arm maintain a position when no external force is applied, but give when a force is applied. I see the "dampening" feature under the joint, axis properties, but I cannot find a spring feature. Is there a way to do this?
answered 2012-11-14 14:07:47 -0500
hsu gravatar image
take a look at this spring test world
it checks equivalence between erp/cfm and spring constants.
see video of it in action. Left most sphere uses a plugin that simulates spring forces, right 4 spheres have prismatic joints with 0 limits with different combinations of cfm and erp. The world file contains explanation on the underlying equations.
answered 2012-11-14 10:35:51 -0500
Erik Stoltenborg gravatar image
updated 2012-11-14 10:38:38 -0500
As far as i know, there is no such joint in gazebo (ODE/Bullet), however you could write a simple model plugin to achieve this.
In this plugin, you can use the following code (its better to define variables and pointers in load, but to get the idea):
    public: void OnUpdate()
      double rest_angle = 0;
      double stiffness = 2;
      physics::JointPtr springjoint;
       springjoint =  this->model->GetJoint(int _joint_index);
      double current_angle = springjoint->GetAngle(int _index).Radian());
      springjoint->SetForce(int _index, (rest_angle-current_angle)*stiffness);
Use this code, along with these tutorials and the API and you should be fine!
2 followers
Asked: 2012-11-14 00:23:57 -0500
Seen: 3,601 times
Last updated: Nov 14 '12
