Shading and rendering in the URDF tutorial
asked 2019-01-29 11:01:25 -0600
strombom gravatar image
updated 2019-01-29 15:57:33 -0600
I have followed the URDF tutorial and made my own robot: http://gazebosim.org/tutorials/?tut=r...
I have not changed the rrbot.world file with it's sun lighting and I use gazebo materials, Gazebo/Orange.
The problem is that the shading is very strange, for example the wheels change between orange and black when they rotate, it's like the light source is rotating with the wheels.
For the meshes I have tried STL and Collada exported from onshape.
This is the robot rendered in gazebo: image description
This is the robot rendered in rviz: image description
I have tried many different ways of <material> tags inside the <visual> tags:
<material>Gazebo/DarkGrey</material>
  <script>Gazebo/DarkGrey</script>
  <script>
    <name>Gazebo/WoodPallet</name>
  </script>
Why are the visuals in Gazebo rendered so porly? I'm not sure where to start looking for a solution.
C:\fakepath\goal.sdf
Edit: I changed all meshes to STL and now it looks better. I will leave it at that but it would be interesting to know if it's possible to override bad material properties in Collada files.
image description
