GAZEBO_MODEL_PATH on the command line?
asked 2019-03-12 21:40:26 -0500
clydemcqueen gravatar image
I understand that I can use custom models using the GAZEBO_MODEL_PATH:
export GAZEBO_MODEL_PATH=path/to/models
Is there a way to do this from the command line?
Thanks.
Not sure I understand the question, you can use the command you mentioned on the command line, right?
chapulina gravatar imagechapulina ( 2019-03-13 15:49:47 -0500 )edit
