protobuf Version verification failed
asked 2019-03-23 06:04:23 -0500
TouchDeeper gravatar image
updated 2019-03-24 09:21:48 -0500
Hi, I want to run a launch file, error about protobuf version occur:
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.0.131
[Wrn] [msgs.cc:1655] Conversion of sensor type[depth] not suppported.
[Wrn] [Event.cc:87] Warning: Deleteing a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
[libprotobuf FATAL google/protobuf/stubs/common.cc:61] This program requires version 3.4.0 of the Protocol Buffer runtime library, but the installed version is 2.6.1.  Please update your library.  If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library.  (Version verification failed in "/home/wang/ridgeback_cartographer_ws/protobuf/src/google/protobuf/descriptor.pb.cc".)
terminate called after throwing an instance of 'google::protobuf::FatalException'
  what():  This program requires version 3.4.0 of the Protocol Buffer runtime library, but the installed version is 2.6.1.  Please update your library.  If you compiled the program yourself, make sure that your headers are from the same version of Protocol Buffers as your link-time library.  (Version verification failed in "/home/wang/ridgeback_cartographer_ws/protobuf/src/google/protobuf/descriptor.pb.cc".)
Aborted (core dumped)
What confuse me is Version verification failed in "/home/wang/ridgeback_cartographer_ws/protobuf/src/google/protobuf/descriptor.pb.cc".), the workspace mentioned here is not the workspace include the launch file, and if I delete the /home/wang/ridgeback_cartographer_ws, the error still be the same. How can I delete the link between the protobuf and /home/wang/ridgeback_cartographer_ws? Gazebo version is 7.
update: I used to build ridgeback_cartographer_ws in my ubuntu. I guess it is because of the protobuf built with the ridgeback_cartographer_ws crash the protobuf come with gazebo. I test the tutorial of gazebo, there is also the error occur:
I don't know how to delete the protobuf built with ridgeback_cartographer_ws. Can you provide some advice?
answered 2019-03-24 20:30:02 -0500
I uninstall the protobuf by sudo apt-get remove libprotoc-dev, remember to take a screenshot of the package uninstall with the protobuf. and reinstall the protobug by sudo apt-get install libprotoc-dev, then reinstall the package uninstall with the protobuf. The error pass.
2 followers
Asked: 2019-03-23 06:04:23 -0500
Seen: 295 times
Last updated: Mar 24
