The Odometry msg isn't updating
asked 2019-04-01 15:02:11 -0500
The odometry topic doesn't update the robot pose while moving it or changing its position using gazebo tools. I have tried it using turtlebot and Husky robots and I'm just running this command to run turtlebot in gazebo roslaunch turtlebot_gazebo turtlebot_world.launch then in another terminal rostopic echo /odom the message is published but the position in it doesn't change
Can you please specify which ROS and GAZEBO versions are you using. I have tried this in melodic which has turtlebot3 and it works perfectly.
shiveshkhaitan gravatar imageshiveshkhaitan ( 2019-04-02 09:34:41 -0500 )edit
