How to echo a topic if not using ROS?
asked 2019-04-29 18:03:16 -0600
Wireline gravatar image
Hi Somehow despite being a ROS user for a couple of years, I never realised gazebo has its own publisher / subscriber system that works separately from ROS! I am guessing this somehow works with plugins, however is there an equivalent of
rostopic list rostopic echo
That can be run from the command line to simply monitor the output from the plugins? Or does this need to be added as a cout statement?
Additionally, are the nodes you ca initialize different from ROS nodes? I have read the tutorials but still feel unclear,
Thank you!
2
answered 2019-04-30 10:45:58 -0600
rasecg3 gravatar image
You can use the gz command for doing it. There are nice things you can do using gz. Give a try and type gz on your terminal and it will appear the help message with all your options.
For your question in specific, using gz topic --echo <topic> will show the topic messages. For see all running topics, you can run gz topic --list
Asked: 2019-04-29 18:03:16 -0600
Seen: 202 times
Last updated: Apr 30 '19
