The modle can't show in gazebo
asked 2019-06-10 08:42:05 -0500
*1. This is from the tutorial *http://gazebosim.org/tutorials?cat=gu...
*2. This is the SDF file *
<sdf version='1.6'>
<model name="velodyne_hdl-32">
  <!-- Give the base link a unique name -->
  <link name="base">
    <!-- Offset the base by half the lenght of the cylinder -->
      <mass>1.2</mass>
        <ixx>0.001087473</ixx>
        <iyy>0.001087473</iyy>
        <izz>0.001092437</izz>
    <pose>0 0 0.029335 0 0 0</pose>
    <collision name="base_collision">
        <cylinder>
          <!-- Radius and length provided by Velodyne -->
          <radius>.04267</radius>
          <length>.05867</length>
        </cylinder>
    <!-- The visual is mostly a copy of the collision -->
    <visual name="base_visual">
  <pose>0 0 -0.029335 0 0 0</pose>
    <mesh>
      <uri>model://velodyne_hdl32/meshes/velodyne_base.dae</uri>
    </mesh>
  <link name="top">
<!-- Add a ray sensor, and give it a name -->
<sensor type="ray" name="sensor">
  <!-- Position the ray sensor based on the specification. Also rotate
       it by 90 degrees around the X-axis so that the <horizontal> rays
       become vertical -->
  <pose>0 0 -0.004645 1.5707 0 0</pose>
  <!-- Enable visualization to see the rays in the GUI -->
  <!-- Set the update rate of the sensor -->
<ray>
  <!-- The scan element contains the horizontal and vertical beams.
       We are leaving out the vertical beams for this tutorial. -->
  <scan>
    <!-- The horizontal beams -->
    <horizontal>
      <!-- The velodyne has 32 beams(samples) -->
      <samples>32</samples>
      <!-- Resolution is multiplied by samples to determine number of
           simulated beams vs interpolated beams. See:
           http://sdformat.org/spec?ver=1.6&elem=sensor#horizontal_resolution
      <resolution>1</resolution>
      <!-- Minimum angle in radians -->
      <min_angle>-0.53529248</min_angle>
      <!-- Maximum angle in radians -->
      <max_angle>0.18622663</max_angle>
    </horizontal>
  </scan>
  <!-- Range defines characteristics of an individual beam -->
  <range>
    <!-- Minimum distance of the beam -->
    <min>0.05</min>
    <!-- Maximum distance of the beam -->
    <max>70</max>
    <!-- Linear resolution of the beam -->
    <resolution>0.02</resolution>
  </range>
</ray>
    <!-- Vertically offset the top cylinder by the length of the bottom
        cylinder and half the length of this cylinder. -->
     <mass>0.1</mass>
       <ixx>0.000090623</ixx>
       <iyy>0.000090623</iyy>
       <izz>0.000091036</izz>
    <pose>0 0 0.095455 0 0 0</pose>
    <collision name="top_collision">
        <cylinder>
          <radius>0.04267</radius>
          <length>0.07357</length>
        </cylinder>
    <visual name="top_visual">
     <pose>0 0 -0.0376785 0 0 1.5707</pose>
     <mesh>
       <!-- The URI should refer to the 3D mesh. The "model:"
           URI scheme indicates that the we are referencing a Gazebo
           model. -->
       <uri>model://velodyne_hdl32/meshes/velodyne_top.dae</uri>
     </mesh>
<joint type="revolute" name="joint1">
  <!-- Position the joint at the bottom of the top link -->
  <pose>0 0 -0.036785 0 0 0</pose>
  <!-- Use the base link as the parent ...
(more)
What is your problem again?
kumpakri gravatar imagekumpakri ( 2019-06-11 04:25:40 -0500 )edit
