ATLAS dimensions, DOF locations
asked 2013-04-08 23:26:31 -0600
Dear all,
Can anyone have the draw of ATLAS links dimensions and DOF distribution and location?
Best!,
Mario
answered 2013-04-09 17:03:56 -0600
hsu gravatar image
Atlas is specified via URDF, its documentation with graphical illustrations can be found here.
The Atlas URDF starts out as a xacro macro, as indicated in the header, atlas.urdf.xacro uses macros defined in included atlas_simple_shapes.urdf and others to expand into atlas.urdf at compile time.
Basic idea reiterated here:
A Model is composed of a collection of rigid-body Links and Joint constraints. The transform between Links are defined in corresponding Joint blocks. So for example, take a look at this Joint block in atlas_simple_shapes.urdf.xacro:
<joint name="back_lbz" type="revolute">
    <origin xyz="-0.0125 0 0" rpy="0 -0 0" />
    <parent link="pelvis" />
    <child link="ltorso" />
Above basically says: The transform from pelvis Link frame to ltorso Link frame is defined by a linear translation of (-0.0125, 0, 0), followed by Euler rotation of (0, 0, 0) radians.
A set of c++ URDF data structures are described here and a corresponding parser is in urdfdom.
Visualization
One way to visualize URDF model is with rviz. Starting with this DRC Tutorial, you can add a TF object:
image description
which will display Link frames:
image description
How to visualize COM of Atlas? is it possible?
vncntmh gravatar imagevncntmh ( 2013-05-30 23:38:12 -0600 )edit
Gazebo allows you to view the center of mass through the "View menu"
nkoenig gravatar imagenkoenig ( 2013-08-02 14:48:21 -0600 )edit
Asked: 2013-04-08 23:26:31 -0600
Seen: 323 times
Last updated: May 30 '13
