Can't find atlas_msgs pack after 2.3 update.
asked 2013-04-09 10:54:34 -0600
Luis Filipe Rossi gravatar image
After updating drcsim to version 2.3 it won't compile anymore my ROS application as it cannot find the package atlas_msgs anymore. How should i proceed?
Best regards,
LR
I'm seeing this trying to write a python module; I have nightly build and can't find atlas_msgs or osrf_msgs
dcconner gravatar imagedcconner ( 2013-04-10 10:27:48 -0600 )edit
I have verified this with the 2.3 deb and a source build. The command rosmsg package osrf_msgs shows osrf_msgs/JointCommands, but it won't import into python. EDIT: see answer below.
scpeters gravatar imagescpeters ( 2013-04-10 11:00:42 -0600 )edit
answered 2013-04-10 13:40:00 -0600
hsu gravatar image
one alternative is to do one of below:
>> import roslib; roslib.load_manifest('atlas_msgs')
or
>> import roslib; roslib.load_manifest('any_ros_package_that_depends_on_atlas_msgs')
before
>> import atlas_msgs
Well, I am using C++ and no python. Any help on that?
Luis Filipe Rossi gravatar imageLuis Filipe Rossi ( 2013-04-10 15:04:25 -0600 )edit
answered 2013-04-10 18:47:46 -0600
gerkey gravatar image
A C++-specific answer that mirror the Python answer:
roscreate-pkg mypackage atlas_msgs
Inside mypackage, this C++ file will compile fine:
#include <atlas_msgs/AtlasCommand.h>
int
main(void)
  atlas_msgs::AtlasCommand ac;
  return 0;
answered 2013-04-10 11:17:39 -0600
Try following the steps in the Atlas Control with Python tutorial
Create a ros package with dependencies on atlas_msgs:
roscreate-pkg tutorial_atlas_control atlas_msgs
Then load the manifest at the start of your python program:
#!/usr/bin/env python
import roslib; roslib.load_manifest('tutorial_atlas_control')
import rospy
import atlas_msgs
WHen i tryed "roscreate-pkg mypackage atlasmsgs" before it could not find atas_msgs. I am goint to try again and if it does not work i will come back here...
Luis Filipe Rossi gravatar imageLuis Filipe Rossi ( 2013-04-10 19:18:43 -0600 )edit
You probably didn't source the drcsim setup file. Do that first, to establish your ROS environment: source /usr/share/drcsim/setup.sh.
gerkey gravatar imagegerkey ( 2013-04-11 10:55:48 -0600 )edit
Asked: 2013-04-09 10:54:34 -0600
Seen: 252 times
Last updated: Apr 10 '13
